CMC Designs
CMC Designs
Postby Spit » Wed Mar 12, 2008 11:53 pm
With many of you becoming proud owners of CMCs this year, I thought I might bring up the idea of a design repository again, which would probably end up taking residence in the Oracle.
I have a few points (Corel Draw pun intended) to be addressed before starting though.... including finding out if anyone else is interested!
1) It would obviously be best if all submissions were in the same file format, preferably one that can be used by all machines. I know Gunnars can import Windows Meta File (*.wmf) and I suspect other makes can as well - can a Wizard/Valiani/Other makes owner please confirm this and let me know if there are any issues? I will provide a sample file below to test this theory!
2) Keeping the designs machine-unspecific means that v-grooves, reverse bevels and the like will have to be set manually after you import the shapes. Would it be better to have a standard colour coding (say red for v-grooves, blue for reverse bevel, green for normal top mat opening, purple for second mat opening, etc) or would it be easier just to have a txt file included with a few notes on how to use the shape?
3) Considering the above, would you prefer machine specific files with everything ready set as well to make it easier (if so, it'll need volunteers for each machine to convert them)
If there's anyone out there that wants to help with this, please let me know. Well here's a test file use right-click & save as here.....
And this is what it's supposed to produce, v-groove outside & double mat openings..... I'll try and use a darker mount next time so that the v-grooves show better!
Steve.
During business hours : My status
Spit
Organisation: Framing Mad
Gunnar Computerised Mountcutters
Postby kev@frames » Tue Mar 18, 2008 9:13 pm
I dont think I can actually import anything on a wizard other than wzx files or wiz files, but i can use path trace to manually copy your design from the image download. I had a go, took about five minutes (and thats only the 2nd time ive used path trace, the bundled wizard program on top of mat designer).
Wizard would charge $50 for same.
If there is a standard colour key - eg white outside cut, red inside cut, green v groove or whatever, that may be useful to all users.
kev@frames
Interests: 4 or 5 ...
Postby Spit » Tue Mar 18, 2008 9:23 pm
Can you try a direct copy/paste? That is - open the file in open office draw (if you have it) or corel draw, select all, copy, and then in the wizard software, paste (control-v may work).
Steve.
Spit
Postby Merlin » Tue Mar 18, 2008 9:59 pm
Can you convert to either .PLT files or .DXF files.
Valiani can import both into their software.
Others have to go through Corel
Merlin
Organisation: Merlin Mounts
Interests: Aviation
Postby kev@frames » Wed Mar 19, 2008 12:31 am
no problem importing the file as an image, into wizard path trace. But its still a manual excercise to copy over the image.
kev@frames
Postby WizSteve » Wed Mar 19, 2008 3:17 am
FYI, PathTrace can import DXF files... in fact, I'm pretty sure every CMC brand supports DXF in some fashion.
The problem with DXFs though is that there's 100 ways under sun to specify arcs, so not every program that saves a DXF (e.g. Corel, Abode Illustrator, Auto CAD, Visio, etc.) saves it the same way.
WizSteve
Postby WelshFramer » Wed Mar 19, 2008 10:24 am
Seems to me as if it would be a good idea to have a generic library of, preferably, DXF files - or whatever template authors can manage - as well as specific libraries for each brand of CMC.
Original authors could be asked to generate generic copies of their templates. Anyone who then translates them for a specific CMC would then submit those to the specific CMC library.
It would save duplicating work that had already been done by others.
Mike Cotterell
Neuadd Bwll Framing
http://www.welshframing.com
My status
WelshFramer
Return to Technology - CMC's Computers Etc
  • Advertisement
Be a Fan of The Framers Forum
Picture framer's knowledgebase
Members Map Header
Members Map
More info
Resources Header
Contact Forum Admin
Directory
Cove Box Designer
Download Designer
General supplies
Glass
Machinery
Mounts/Mountboard
Artists
Conservators
Prints
Software
Tuition
UK Medals
Framers Forum Live!
Support Header
Crimson
White
Green
Violet
Advertise Header
Forum Banner Ads
