BACK OF FRAME
BRUMMIEFRAMER
Organisation: HOME
Interests: OIL/WATERCOLOUR PAINTING,HARMONICA, GUITAR, FOOTBALL.
BACK OF FRAME
Post by BRUMMIEFRAMER »
Which is the best way to show a certificate of authenticity on to the back side of a frame, the frame is 16 x 10 inches the certificate is 8 x 6 inches.
Re: BACK OF FRAME
Plastic sleeve from a loose leaf binder, cut the holes off to make it look nicer perhaps. Stick that to the back and put the cert in.
Some say certs should be kept separate.
Nigel Nobody
Re: BACK OF FRAME
Post by Nigel Nobody »
I use mylar envelopes that I got from an archival supplier down here. I got them to make A4 and A2 size and I just attach them to the back with ATG.
Jonny2morsos
Re: BACK OF FRAME
Post by Jonny2morsos »
Certificate holders are available. Customer of mine I do mounts for uses A5 size and prints his own certs. which he numbers and signs. I often photocopy, laminate the copy put that on back of frame and suggest the customer keeps the original in a safe place.
John.
RobinC
Re: BACK OF FRAME
Post by RobinC »
We use these
http://www.viking-direct.co.uk/catalog/ ... DDEmpty.do
They have no holes perforated in them so they look a lot better than binder sleeves - they are available in different sizes are fairly cheap, and look good when attached to the back of the frame.
RobinC
The Crofter
Interests: Photography
Re: BACK OF FRAME
Post by The Crofter »
Try these polyprop pockets from Lion
http://www.lionpic.co.uk/Catalog/Produc ... earch=6339
Pat
