I have got another one on the go. This time I used Unibond for the PVA constiuent. I had a Box of Pollyfilla powder, but I used some pumice powder that was hanging about. It gives the mixture a slightly grey look.
Talking of tinting. I routinely mix dry powder paint with ripple paint. You can get quite a lot in and the paint will absorb it. Some of my samples are at least 15years old and no signs of deterioration. You can get concentrated pigments in liquid form at your local DIY shed.
Anyhow I can't tell the finished result until the morning when it has had time to harden. I sprinkled some dry pumice on the wet surface and also some yellow and brown dry pigment. At the moment it looks, well errrrrr....intriquing.
*The leather effect is a piece of whatsit. A couple of coats of manky brown (raw umber+dab of white) followed by well diluted black. Stipple and dab with a paper towel.
Wax/wirewool and polish whe thoroughly dry. The 'orange peel' surface of the greyboard works in your favour here. Notice on the demo how I've left the black heavier in the corners. Nice touch. It doesn't really simulate leather, rather it simulates imitation leather.
One thing though. To use a waxed finish mount under glass can have wierd effects if you don't space the glass away.
For old faded velvet, get some mid-toned mountboard, red or green works best. If you can get an Ingrés paper, so much the better: It simulates the weave lines. Just splodge it with diluted black or dark brown in a random manner. It looks awful until it dries. When it's under glass the effect is quite uncanny (don't wax it).
Hand finished stone effect
Re: Hand finished stone effect
OK so this is not quite as textured but the customer brought in these tiles she had made and turned into an ethnic type lot and she gave me carte blanche in the framing. I thought a wide frame with a feel related to the tiles could work so started off blackening areas of the moulding with a sponge
then sponged on some white covered whole lot with a beige wash only 3 attachments ! OK
Alan
waxed then put on darker wash buffed off with steel wool to allow the grain to come up
then spattered on some light and dark speckle
I sunk the tiles and the big bead into the mount, added a natural ethic slip washed in black which covered the edges of the box (John's favorite cuckoo clock type but it wasn't too deep and the frame is about 100mm wide so it looks OK
Alan
- Organisation: Framing Mad
Nice!
Just a tad more subtle than my sledgehammer to crack a nut effort!
