I went to have a look at a potential job today and was shown into a room with a snooker table and on the snooker table was a piece of 3mm perspex 1.8m long x .95m wide. It had been painted using transparent type paints and had pieces of dried flowers and grass which had been sort of encapsulated in plastic.
We both agreed that it would look good mounted away a white painted back board (by about 10mm) and the framed in a box 25mm deep with no glass or acrylic as the artwork is already shining.
The problem was/is how to mount the perspex art to the base board. I need something like my sketch shows, if they exist. I got the idea from the old Victorian street signs that have been mounted into brick walls.
If they don't exist, has anyone got any ideas??
I was then shown two circular pieces approx. 24" diameter, which I could use the same fixings.
You could use those mirror screws/bolts that are capped - looking at your sketch the bolt would do the job, just put it in from the front and cap it.
But I'd suggest glass - as you say - it's already 'shiney' so there's nothing to lose visually - especially if it's optically coated - and that's a lot of space behind the artwork for dust to gather/insects to crawl behind to die - not easy to clean, plus regular cleaning may dull the finish. Also whatever the dried flowers are encapsulated in may well yellow, so UV glass may help.
Ask the customer which they'd prefer - to clean the artwork, with all it's dust-gathering nooks and crannies; your backing behind/around the artwork; the spacers ...... or a nice flat piece of glass. I know which I'd prefer
Thanks for your help guys, much appreciated. I like the idea of the hexagonal bolt and nylon bush, but I think I will persue the lovely chrome Magco "thingys"
