Hot Press Vacuum Press model wanted.
I can collect up to 50 miles from London.
thanks
Hot Press Vacuum Press wanted
- Organisation: can you feel it ltd
- Interests: chess
- Organisation: CanvasCrew.co.uk
- Interests: Football, family, work!
Re: Hot Press Vacuum Press wanted
I've sent you a private message
- Organisation: Photofusion
We have an HGP 360 which we bought new from Hotpress via Silverprint in London. Has had relatively little use, as 95% of the jobs we do are run on the JM44. Although it is very handy for finishing off a few jobs, and preheating dibond and aluminium in the winter months (new cold snap coming), we could do with the space to put in a new cutting table.
Comes with a few part rolls of materials - almost full roll of Unimount, most of a roll of, bit of standard gloss, spare vacuum foam and the dreaded massage wheel (which is missing four teeth)... All Electrics / electronics are good, and holds full vacuum. Sat on a seriously sturdy engineering bench, in sunny southwest London (Brixton).
Press weighs 111KGS and requires 18 Amp powersupply.
- P1040977.jpg (64.84 KiB) Viewed 4438 times
- P1040974.jpg (71 KiB) Viewed 4438 times
- P1040970.jpg (107.47 KiB) Viewed 4438 times
- P1040968.jpg (92.59 KiB) Viewed 4438 times
- Interests: chess
Check your message box Richard.
- Organisation: Studio419
- Interests: Framing
Do you have a cost?
We're hoping for £2000 ono...
- Steve Goodall
- Organisation: Wessex Pictures Group
That is a very fair price!!! Bargain!!!
Spring clean HGP360 - got to go
Somehow, I'd overlooked that we still have our HGP 360, as described a couple of years ago.
With Spring here, we need to use the space. In used, but good condition, everything works as it should. Make me an offer!
