Easy positioning
Easy positioning
Is it a multi aperture mount?
dream 1.JPG (573.88 KiB) Viewed 13755 times
Nope! It's a 5mm foam board template cut to half a millimetre accuracy on the CMC to position these block mounted photos.
dream 2.JPG (538.42 KiB) Viewed 13755 times
Re: Easy positioning
Driftwood frame mitred on its side and capped with the same moulding - clamped for nice tight fit.
dream3 001.JPG (93.76 KiB) Viewed 13749 times
kev@frames
Interests: 4 or 5 ...
Post by kev@frames »
what moulding is that, John?
http://www.arqadia.co.uk/productdetails ... =790111000
Comes in a wider profile too, which is handy for a deeper box.
GUNNAR
Post by GUNNAR »
What a very good idea. As ever.
Used up a fair few skinny foam board offcuts on the spacers, finished with same colour as mounting board (alphamat artcare 'dusk grey')
spacers 026.JPG (98.85 KiB) Viewed 13663 times
All Done.
done 001.JPG (116.41 KiB) Viewed 13663 times
JohnMcafee
Organisation: Scenes
Interests: Picture Framing
Putting the world to rights
Post by JohnMcafee »
Excellent! :clap:
It's a Quattlebaum. :clap:
Nice job :clap: did you do the blockmounting John, or did the customer bring them in like that
I didn't do the block mounting - don't offer it either.
Love it! Great idea!
:clap: :clap: :clap:
A Curious framer wrote:How did you mount them?
Ha! - I thought no-one was going to ask, would be the first thing I'd ask.........
They're on blocks of 25mm MDF with a hole top centre - I could easily mount them with a melinex wrap; pros and cons were discussed - nope, they're mat and glossy is out, especially with AR glass (which isn't too apparent in the photos) I thought about embossing the shapes on the back of the mounting board and placing screws inside those shapes - that would be a bit of grief face-down but do-able, but what would cause more "damage", 4 holes or 4 blobs of wood glue?
Wood glue it was, the actual 'artwork' is already stuck to MDF anyway.
FFrames
Organisation: TBD
Interests: Art
Post by FFrames »
How did you make those spacers? It looks like you mitre cut them, but then the mount board on top overlaps?
They're 90 degree cut on the CMC, foam board and the final strips of mount board.
benjiman grapes
Organisation: GN Framing
Interests: I'm a philosophical tea drinking film geek gamer with OCD. My family is established in Norfolk, England prior to 1686 and I butter with a spoon.
Post by benjiman grapes »
Nice work robo, nice work indeed.
I use a very cheap mount board to cut templates when I have multi images to float mount.
It's a super way to save time.
CMC always comes in handy for things you didn't even think of when purchasing. Like cutting strips for box frames. Always to the correct size everytime & while their cutting I can have a sip of tea.
Benjiman Grapes
DURUM PATIENTIA FRANCO
| www.benjiman.co.uk | benjiman.grapes@hotmail.co.uk |
pramsay13
Post by pramsay13 »
Did you just make up a quote? Someone call the quote police :lol:
I use the CMC for many things that I didn't think of when purchasing, especially accurate positioning and that could be with a template like this which is from scrap (and even after being used for this it was used for spacers) or embossing/scoring.
I also use it, every time, to emboss (de-boss, whatever) washlines. I set it so as you can hardly see the lines and then mark the corners ever so lightly with a 4H pencil and then carry on as normal. But it's not normal, it's 100% accurate.
Also use it to cut melinex if I want accuracy or any shape that I can create with my limited software/tech capability, by putting the melinex under a scrap of mount board and increasing the blade depth a fraction.
