oval cut using Valiani CMC
mtfuji
Organisation: Forster Photos & Framing
Interests: Photography AFL
Post by mtfuji »
I have a Valiani Mat Pro iX CMC which I love
However I find lately that oval cuts are not going the whole way round.
It will cut arches and other fancy cuts and also small ovals but anything over about 250mm and the cut comes up short.
I use V studio but I also tried on FMD and it had the same problem
Techs in Australia don't know the solution so I am wondering if anyone else has had this problem and knows how to fix it
Many thanks
Mark
IFGL
Re: oval cut using Valiani CMC
Post by IFGL »
Yes :D
There is a little white plastic topped screw on the back of the machine, this determines how far round it travels when cutting ovals, there are two of these on the front for the start and stop points for straight cuts, bare with me I will find a photo.
mtfuji
Post by mtfuji »
Thanks :D
I can see the 2 on the front but not the one on the back
a photo would be great
IFGL
Post by IFGL »
I can't find one on the tinterweb, I will get Jamie to photograph it when he gets in, it's my day off today.
I've had this problem for ages, on tiny ovals it does about 3 complete laps and on huge ones it stops about 40mm short!
But it's only on the green head, not the yellow head, so I don't see how it can be fixed on the machine, surely it's done in settings?
I get round the problem by turning the design 180 degrees and re-cutting!
IFGL
Post by IFGL »
I sorted mine out by actually fixing it :D
OK - looking forward to sorting mine the same way then :-)
IFGL
Post by IFGL »
So it is right at the back at the end of the long boom it has a locking coller that may have come loose.
All the machine settings have to control physical things, and all of these need to be set up correctly to work,
IFGL
Post by IFGL »
It will always go quite away further round on small ovals because it lowers the head incrementally on these to create a smooth entry and a nice oval.
Merlin
Organisation: Merlin Mounts
Interests: Aviation
Post by Merlin »
Mark. Can you send your CMC serial number please.
The reason is if the machine is before 2007 there is not a screw regulator on the back of the Y arm.
See Photo.
oval air regulator CMC iX.jpg (209.41 KiB) Viewed 34816 times
John GCF
IFGL
Post by IFGL »
Yours is cleaner than mine.
mtfuji
Post by mtfuji »
I have that screw regulator on mine.
The coller seems fine
Can I adjust it?
And yes Merlin yours is cleaner than mine too
IFGL
Post by IFGL »
Yeah you can adjust it., all it wil do is make the cut travel a bit further.
mtfuji
Post by mtfuji »
wow !
half turn anti-clockwise and it cuts like a treat
Thankyou so much
Mark
Post by Graysalchemy »
Wow I am intrigued to see you poor valiani users have to set something for this. The trucut has an algorithm in the software which adjusts the amount of cut depending on the diameter of the oval, perfect cut every time :giggle:
The Val software can also adjust the cut, has to, for different thickness boards at least.
IFGL
Post by IFGL »
I like the sound of the algorithm, I can you buy them for the valiani?
IFGL
Post by IFGL »
Users don't really have to fiddle with that screw, it's set up at the factory and the rest is done on the machine settings, I managed to alter mine when I moved the machine, must have caught the screw some how, anyway easy fix and should not need faffing with again.
CR-W
Organisation: Ringwoods Framing
Interests: Narrowboating, motorcycling, dog walking, art and music.
Post by CR-W »
Well, seven years later this thread solves the same problem for me too. Thanks chaps :D
IFGL
Post by IFGL »
You are welcome 🤣
