What have Gunnar got up their sleeve?
Grahame Case
Post by Grahame Case »
Lemon_Drop wrote:
Grahame ask Sarah at Gunnar for a copy of the software, it will work without the machine an at least give you an idea of what it can do before you get the 601.
cheers Lemon_Drop,
I'll get in contact with Sarah, i have her business card at the shop.
it would be ideal to try out the software before hand,
osgood
Post by osgood »
Spit wrote: That's what I mean - it shouldn't just vanish, even if you haven't hit enter.
Spit, hitting the enter key after entering the sizes of a mat and opening is what activates it. I see no problem with this at all and have been using it quite successfully for about 6 or 7 years.
Just like if you enter a number, then a plus sign, then another number into a calculator, it doesn't automatically tell you the answer until you activate the function with the '=' key!
As far as drawing special shapes is concerned, I have had no problem drawing shapes with Corel Draw on the rare occasion that has been necessary. I think that has been three times in 6 or 7 years. Many special shapes can be easily made up using several of the huge number of standard shapes and modifying their properties to get a quick result.
