BBest?
silvercleave
Organisation: thought I was
BBest?
Post by silvercleave »
I would like to delete all the mouldings in BBEST, have deleted files holding info but when going to BBEST it still shows the mouldings?
Any ideas John
Regards
Ian
JohnMcafee
Organisation: Scenes
Interests: Picture Framing
Putting the world to rights
Re: BBest?
Post by JohnMcafee »
Deleting "files holding info" isn't for the faint hearted, Ian, nor is it something that I would ordinarily recommend in BBEst (or any other software for that matter). :)
However, perhaps this will help: -
To delete the moulding lists of your various suppliers use the "Remove Table" button in the Stocked Mouldings screen.
On the other hand, items in the Stocked Moulding screen have to be removed one line at a time by placing the pointer on the relevant line and clicking the Delete button.
I am not sure if this has answered your question.
Why do you want to delete all of your mouldings? Have you suddenly run completely out of everything?
silvercleave
Re: BBest?
Thanks John
Is it possible to start from scratch and reload the complete prog?? Please?
Ian
kev@frames
Interests: 4 or 5 ...
Re: BBest?
Post by kev@frames »
Hi Ian,
you can uninstall it from the control panel:
win xp or 7: start/settings/control panel/add or remove programmes/bbest/remove this programme
check to see if any folders remain in c/programme files/ (bbest) and delete or rename them.
then reinstall it clean.
if you still have any problems from the reinstall, you can uninstall it again and delete any registry entries if necessary, John will tell you where they are.
I've uninstalled and reinstalled that way before.
Just make sure you have your serial key, else you'll have to phone john like I did... twice :oops:
any help?
silvercleave
Re: BBest?
Thanks Kev, think I might have to phone, cannot remember number, but thanks for the info, glad I'm not the only one :oops: :Slap:
