Using Slope Box Designer values with a Wizard
Share your CMC experiences.
Or seek help and advice
Postby kev@frames » Wed May 26, 2010 10:19 pm
Overview: Why do you want to use a third party utility, when you can design a cove mount/slope sided box quickly and simply using Wizard Mat Designer (or the unfortunately named WMD, as it will henceforth be known) .... Simple answer. John's slope sided box designer does all that working out for you. Less trial end error fiddling about and calculating/guessing depths etc. Then it is a simple matter to enter the values it gives you into a WMD template.
First have a look at this video. It shows you how to make a slope box template of your own from scratch in wizard mat designer:
http://theframersforum.com/viewtopic.php?f=26&t=4921
Or you can download a template to play with from this sub-forum's Designs section
Once you have designed a slope box insert using the slope box designer, you can enter the values it gives you into wizard mat designer once you have loaded the template (called cove-1-licensed)
so create a template as shown in the video, or as described by Sam elsewhere on this forum, or open the cove-1 wizard mat template:
First set the matboard size
Materials size in slope box designer = Matboard size in WMD
S in slope box designer = Reveals value in Layer 1 and Height value in Layer 2/Parameters in WMD (set both to the same value)
C in box designer = width value in Layer 2/Parameters in WMD
X and Y in box designer = Width/height values in Dimensions in WMD
These values will replicate the design generated in slope sided box designer. (You do not need to save any PLT files, just press the Cut button and proceed to the cut screen (cutting engine) and cut the mat.
CUTTING:
Cut from the back
Cut layer1 as a score-line by setting blade to a bit less than your usual v-groove setting. Cut Layer 2 as a full depth cut.
experiment with reverse bevels depending on your box angles
please note- this will only cut on a machine running licensed wizard mat designer software.
kev@frames
Interests: 4 or 5 ...
Loft
Re: Using Slope Box Designer values with a Wizard
Postby WelshFramer » Sun May 30, 2010 11:18 am
Thanks for that, Kev, I'll be trying it out soon.
Mike Cotterell
Neuadd Bwll Framing
http://www.welshframing.com
My status
WelshFramer
Return to Discussion
  • Advertisement
Picture Framer's Oracle
Members Map Header
Members Map
More info
Resources Header
Contact Forum Admin
Directory
Cove Box Designer
Download Designer
General supplies
Glass
Machinery
Mounts/Mountboard
Artists
Conservators
Prints
Software
Tuition
UK Medals
Framers Forum Live!
Support Header
Crimson
White
Green
Violet
Advertise Header
Forum Banner Ads
