Frame Corner Protector Design for Valiani CMC's
Upload/download patterns, templates, designs.
Postby Jonny2morsos » Fri Jan 06, 2012 9:45 am
I did some work for a regular customer just before Christmas and she has returned one frame with damage on the corner. I am certain the damage was not there when she collected it but I have to admit I don't put corner protectors on finished jobs.
She came in with two other good jobs and I had plenty of spare moulding the same so I am going to replace the frame FOC.
However I have decided to better protect finished work in future and have come up with a design for corner protectors I can make on the Valiani CMC out of mount board offcuts.
I cannot attach the design as I get a message saying .fu2 file extension not allowed.
If you want a copy email or PM and I will forward it for you to try. You may have a better one of your own to share or could adapt this one. Feedback welcomed.
Jonny2morsos
Loft
Re: Frame Corner Protector Design for Valiani CMC's
Postby John » Fri Jan 06, 2012 10:09 am
Here, in the design section, you should be able to upload your .fu2 file.
If you have any difficulty with this, please let me know.
John
Site Admin
Organisation: EstLite
Interests: 10
Postby Jonny2morsos » Fri Jan 06, 2012 12:41 pm
Thanks John. Sorry I had forgotten about this section. File now attached below.
30mm corner protector.Fu2
The file can, of course, be amended to suit various frame depths.
Jonny2morsos
Postby Jonny2morsos » Wed Jan 11, 2012 9:41 pm
The file has been downloaded 14 times so I wondered if anyone had any suggestions for improvements. I have created some more to accomodate different depths of frame by enlarging the short side of the rectangle that cuts as a V Groove.
Jonny2morsos
Postby markw » Thu Jan 19, 2012 2:19 pm
J2M - I have a suggestion - make up an fu2 file that has 2 or 4 corners protectors within the cut - by rotating the shapes you can get a more efficient cut - You could also make this up as a .plt file and then cut the shapes when you cut the mount - placing the corner protector cuts within the waste area cut out - cut mount and protectors all in one go.
Mark Wallington GCF
markw
Postby Jonny2morsos » Thu Jan 19, 2012 2:43 pm
As it happens I had already thought of that in the last week or so. To start with i tried rotating the design I had made but as it is made up of three separate shapes it meant rotating all three separately and repositioning so I have now saved them as individual Fu2 files.
As I do new jobs with different depths of moulding I create new files to get a range of sizes
If I don't think the fall out is likely to get used I am doing as you have suggested and using them for the frame i am cutting the mount for.
Jonny2morsos
Postby markw » Thu Jan 19, 2012 2:47 pm
You can group and rotate.
Mark Wallington GCF
markw
Postby Jonny2morsos » Thu Jan 19, 2012 7:16 pm
Just made a new file with one of my modified designs, 20mm depth and 80mm sides, and by rotating one by 180 degrees they fit very nicely in some offcuts I have a huge quantity of that are fall outs from a mount I do for a big customer.
I can see some child labour being employed during school holidays!
Jonny2morsos
Return to Designs
Picture Framer's Oracle
Members Map Header
Members Map
More info
Resources Header
Contact Forum Admin
Directory
Cove Box Designer
Download Designer
General supplies
Glass
Machinery
Mounts/Mountboard
Artists
Conservators
Prints
Software
Tuition
UK Medals
Framers Forum Live!
Support Header
Crimson
White
Green
Violet
Advertise Header
Forum Banner Ads
