Add an additional moulding
Posted: Thu 01 Mar, 2018 6:59 pm
by Nicole
Is it possible to add additional mouldings such as where they are stacked or maybe a stretcher bar and a frame. We have added the stretcher bars manually in the moulding list as stock as they were not in the moulding ID list (Wessex).
Re: Add an additional moulding
Posted: Fri 02 Mar, 2018 2:30 pm
by JohnMcafee
EstLite has a column for Moulding Location (see screenshot below)
- Mouldings.png (77.76 KiB) Viewed 4050 times
However, if you are referring to stacked frames, they are easily accommodated by use of the plus sign. Up to 5 mouldings can be "stacked" in order (Innermost first)
- Main.png (44.51 KiB) Viewed 4050 times
Two mouldings are stacked in the example above, Moulding 22 is the outer frame and PW1 the inner.
Hope this helps.
Posted: Fri 02 Mar, 2018 8:41 pm
by Nicole
Thank you we were halfway there just didn't know about the plu s sign. We'll give it a go and post again if needs be.
