Tape to use?
- Organisation: AOT Framing
- Interests: Art & Framing
Tape to use?
Hello all, Just about to open a framing shop next week and would like some advice of which acid free tape to use for window mount hinges and also tape/pads for float mounting (not shadow) Any advice would be gratefully appreciated.
Re: Tape to use?
Have a look at the Lion and Wessex catalogues online. I use an acid free whitegummed tape, comes in a big roll. I use with deionised water.
For floating, I use this same tape made into Y hinges. Depending on the size, I usually use 8 hinges. I learnt these techniques from the "Conservation Framing" book by Annabelle Rushton.
There is also the hedgehog technique which you can search for in this forum. Good luck.
Re: Tape to use?
A good 'all-round' tape is Filmoplast P-90. Easy to dispense and reliable. It has a progressive tack, so you can apply it and
peel it off with care. Burnishing it down makes it permanent. It can be removed with careful damping. I have never had to do this
but I've tried it and it does come off.
The best way is to use hand-made paper (comes in various weights) and starch paste. The the paste does have to be carefully
prepared however which is a bit of a faff and applying the paste takes practice. Worth learning the techniques though.
The best form of hinging is to use no hinges at all. Do a search for edge mounting using Mylar and similar methods.
- David McCormack
- Organisation: Framing
Re: Tape to use?
Here are my thoughts about tapes and their uses.
There are two parts to tape; the substrate (the tape itself) and the adhesive.
Tape can be made from wood pulp, cotton rag, linen and Japenese papers such as mulberry tissue.
Wood pulp contains lignin which will degrade over time and as it does it produces acid. The acid is what causes paper to discolour and weaken. Wood pulp needs to have all the lignin removed before it can be used in conservation framing but small traces can remain.
Tape made from cotton rag, linen cloth and Japeneses papers are all naturally lignin free so they make for a much better choice in conservation framing.
Adhesives fall into two categories; sticky self adhesive (pressure sensitive) and water activated (gummed). Self adhesive tape is pressure sensitive so the best bond is achieved by burnishing the tape after application. Self adhesive tape can fail in time and is not usually considered best practice for attaching directly to artwork.
Gummed tape needs to be activated with water for the adhesive to bond. Care needs to be taken not to apply too much or too little water. Gummed tapes are considered a better choice for conservation framing as they are less likely to fail.
Linen cloth tapes are available as pressure sensitive or gummed. They are a very strong tape and not usually recommended for making hinges for paper art as it is better to have the paper hinge weaker that the art itself. However, they are ideal for hinging together the window-mount and under-mount. Self adhesive is fine for this application as the tape is not in contact with the art.
Japanese mulberry tissues and similar are a popular choice for conservation framing as they are light and strong and come in different thicknesses and weights. However you need to apply your own adhesive which will usually be a freshly cooked wheat starch paste.
If you are just starting out in framing I would recommend using the cotton rag gummed tapes as much as possible to attach directly to artwork. Wet the tape with distilled or deionised water using a small brush. Use self adhesive linen cloth tape for hinging window-mounts to under-mounts.
Of course there are methods of attaching paper art to under-mounts without using any tape. For window-mounts a popular method is the platform mount.
For float mounting the usual method is pass through paper hinges or the hedgehog method. Double sided sticky pads, as I think you mentioned , are not a good idea.
Good luck with your new venture and keep asking plenty of questions on this great forum
Re: Tape to use?
Thank you so much for the tips
- Tudor Rose
Re: Tape to use?
There are mini tabletop workshops on a variety of framing subjects - including hinging - at the Guild Weekend at Stratford upon Avon. The classes run from mid morning to mid afternoon on Saturday 18th May and are open to members and non-members to visit.
There's more information here -> http://www.fineart.co.uk/events/schedul ... ing-1.aspx
It will be a great networking and social event, as well as being educational. Members of our Guild's Framers Committee will be on hand to answer any framing related questions. You will also have a chance to look at the entries from the framing competitions and to vote for the entry you consider to be "Best in Show".
