Stringing Large Heavy Oil Painting?
- Organisation: Forest Arts
- Interests: Painting and Art
I have to string a largish oil painting with a heavy frame (160cm x 140cm). What would be the recommended position for the D-rings? Any other advice would be gratefully received.
Re: Stringing Large Heavy Oil Painting?
I wouldn't use a cord or wire. I would make some cleats.
Or Lions D Ring/Strap Hangers 6594/5768 or similar
Where would you position the D-rings? ¼ way down? ⅓?
I agree with not using wire between the hangers.
It has to be strung, but how far down from the top is recommended for a large heavy picture and frame?
I hang everything 1/3 down but be aware of hanging strain on frame i.e. make sure that the cord if designed for 2 hanging points at an angle like 60o and set the drings accordingly. I'll try and share a picture.
NO CORD OR WIRE
use strap hangers, with strap hangers you can attach higher up on the frame, around 1/6th of the way down, with screws and wall plugs in the wall
Remember to use bigger screws with bigger/ heavy frames
Has to be strung.
What does that mean? Can you please explain.Foresty_Forest wrote: ↑Mon 07 Sep, 2020 12:39 pmIt has to be strung, but how far down from the top is recommended for a large heavy picture and frame?
-- There can be no holes made in the wall? or what
For normal hanging of paintings the 1/3 down the outside rail is very common.
For heavy framed pictures in museums a wire, cable or chains between the 2 vertical rails of a frame are not normally used. Anchor points for a frame can either be hidden behind the frame or near the top of the wall with cables or chains between the hardware on the frame and the wall anchors. Gigantic frames are hung this way.
The alternative is French cleats and s or steel angle iron under the lower rail of the frame.
- Organisation: Photofusion
Perhaps it has to be hung from rod(s) or cable(s)?
In that case, strap hangers - rod (or cable) to each one. If only one rod/cable is permitted in this game, then perhaps a magical stong beam, connected to the strap hangers might do the trick. Strap hangers around 20% of the way down.
How heavy is a heavy frame?
Print monkey, in the Gallery, with the Carbon Mono-Fillament
