Deep tray frame ID
- Organisation: None
Deep tray frame ID
Hello all
I'm looking for a bare tray frame moulding suitable for a 50mm deep canvas that isn't more than 15mm wide on the face. Lion and wessex nothing, larson can't find anything, r&h same.
I don't currently have the woodworking facilities to make my own or trim down the wider faced deep one from lion.
On Jackson's I noticed they have one in lime, 50x12x59
Same profile in sapelle
Just what I need!
Does anyone know where this might be from please?
Just what I need!
Re: Deep tray frame ID
Hi Megan,
All of the suppliers tat you have mentioned have their own range of different mouldings, which are made for them to the individual profile which they themselves have specified. The get these mouldings produced for the own needs and do not need to go through a third party, who will take a cut from the price of the moulding and therefore increasing the price which the supplier has to pay.
Well, Jacksons art supplies probably do the same! If you do not want to pay the prices, which Jacksons are charging, then the alternative would be to order a quantity of moulding to your own specification, directly from the moulding manufacturer. Obviously this means that you will need to pay for a production quantity, but there will be a price advantage which reflects the larger quanity, but you will have to provide enough storage space for the quantity of moulding when the whole quantity gets delivered to you.
One of the UK companies which can machine mouldings to customer specifications is Norfolk Mouldings and there probably are a few others as well.
- GeoSpectrum
I use Rose and Hollis A45 upside down with a spacer glued and pinned into the rebate to make the base. This will give the depth you need. It's not too hard even with basic facilities. the 'face" of the this moulding is 13mm wide, pretty close to your needs.
I usually fabricate tray mouldings from mouldings and spasers, not necessarily the Rose and hollis mouldings made from the purpose, but whatever I have got in stock that is the right moulding. If it's going to be a painted moulding it can even be a pine moulding. I also don't mind cutting larger mouldings down on my band saw and giving then a quick sanding down to lose the saw marks. I try to use what I've got in stock, to avoid ordering small quantities of mouldings, for just the odd job and buy many of the mouldings that I stock, with the potential for versatility and also cost in mind.
- GeoSpectrum
Me too, but the OP only has basic facilities.
Yeah, no band saw sadly!
- Organisation: Pizienwell Arts
- Interests: Chess, Landscape Gardening, DIY, Drama, Literature, Music, Tennis, Cooking
Where about in Kent are you?
I use Morgan's woodyard in Strood for 'out of product range' mouldings.
Last unusual tray moulding that I needed was 50mm deep (exterior), 40mm deep (interior), 35mm wide (top), 60mm wide (base).
Most economical wood was tulipwood at just under £8.00 (incl. VAT) per metre.
I only got the band saw to slice up thousnnds of feet of old mouldings and turn them into something usable. I don't think that I've got quite as much stock of old mouldings as Prospero, but I've got a lot more than I can probably use in several life times. With the amount of mouldings which I have been able to repurpose so far I have probably paid for my basic cheap band saw many times over.
- Organisation: wood green picture framing
- Interests: work
use any wide flat moulding with your width or similar on its front edge down (a lot have 9mm rebate lip), join with a hoffman if available, if not, side pin and glue. make flat frame from rose hollis F7 and lay underneath.. no unsightly gaps on the inner or joints on outer sides rose hollis will cut in your choice timber if you give them the lead time
