Machining prefinished salvaged wood.
Posted: Fri 27 May, 2022 9:01 am
I have various pieces of 3/4 inch think walnut from dismantling a side board, which was left in our flat by the previous tentant. It's really nice solid wood, but I have been tolds that the wood being previously finished with some sort of varnish is likely to blunt my planer blades and my router bits. I don't actually know if this is true, but if I am to glue this wood together to make display boxes and display cabinets, I will need to machine back the varnished sufaces to be able to create viable glue surfaces.
I don't want to use any visible fixings to construct these boxes and cabinets, so I am also thinking of using loose tenons as the method of contruction and maybe creating a template for routing the slots for the loose tenons. I am thinking of either using a Festool Domino Jointer, or alternatively just a normal router instead. I am still wondering if getting a basic Domino jointer might still be a more worthwile option as it could perhaps be used as an alternative to a Hoffman router by inserting hidden loose tenons inside mitred corner joints which are too deep to just join by underpinning.
Does anyone have any thoughts about this please,
Thanks,
Mark.
Thanks,
Mark.
