Shadow mount question
Orde02
Organisation: Northwood Framing
Interests: Painting, flying, cycling
Post by Orde02 »
Hello all.
A quick question, any help most appreciated. If I'm shadow mounting a small print, what is the best way to secure 3mm foam board to my mount board? I've used ATG double sided tape before but I'm not sure how secure it is. After that I used thread put stitches in each corner, as well as the tape, to mechanically hold the foam board. Perhaps someone can suggest a better way of securing it?
Thanks in advance
Matt
Tudor Rose
Organisation: The Framing Lot
Re: Shadow mount question
Post by Tudor Rose »
We use a small amount of ATG to get the instant hold for positioning and then dots of Evacon-R to secure it more long-term. We put it under weight until the glue has gone off and then it is ready to be used.
Evacon-R is archival and reversible with water should that ever be required - but very unlikely to be needed in these circumstances.
Post by vintage frames »
A simple and short question deserves a simple and short answer -
- do exactly as Tudor Rose said.
If you're not too bothered about conservation, use PVA wood glue instead.
I'm Evacon, but without any ATG. I like that it allows for adjustment before weighting.
Orde02
Post by Orde02 »
Thanks for all the help everyone. I've bought some Evacon to try out.
Regards
Matt
