morso
- Organisation: blackheath frames
- Interests: framing!
Re: morso
hi all
is there a tool for this screw or is it just a pair of pliers to loosen?
both are jammed and i didnt want to damage the knurling if there is a tool
novice i know!!
thanks in advance
novice i know!!
thanks in advance
Re: morso
That's an Allen Key screw.
Most hardware shops will sell you a set, usually on a key-ring.
Just pop the one, the right size, into the centre hole and turn. Might be tight but little or no chance of damaging the screw.
