May sound a silly question but my Morso has started not completing the final cut and leaves a small bit at the bottom back of the moulding (see photo) and for the life of me I can't work out what to adjust to make it a clean cut all the way through, it's had a recently sharpened set of blades fitted but I don't think that's the problem and advice would be welcomed
thanks in advance
Morso miter cut not going all the way help
- Mark Thornton
- Organisation: Underpinner Spares
- Interests: Red wine - lots and lots of it.
Re: Morso miter cut not going all the way help
The setting is mentioned in the later versions of the manual.
Mark
Mark
- JKX
And here’s the manual!
https://www.thegrumble.com/data/manuals ... tsList.pdf
First check there’s nothing obstructing the foot pedal though - and the moving parts inside - sometimes shavings can get trapped and cause problems.
Blades wear down when they are sharpened. so it may be a case if adjusting downward travel with the threaded rod attached to the blade housing - should all be in the manual.
John Turner
- Organisation: Cotswold Frames
- Interests: most things
Many thanks for the reply's will see if i can sort as directed.
