Band Clamps
CreativePhotographer
Organisation: Anna Briggs Creative Photography
Interests: Dogs, creative photography and walking..... lots of walking!!
Band Clamps
Post by CreativePhotographer »
Good evening Framers... just putting this out there really. I met a friend today who's a carpenter and he makes and sells his own frames. Because he's a carpenter and not a framer he uses band clamps and not an underpinner. From what he was telling me, it seems pretty straight forward. I am just getting started and the framing I will be doing will be quite simple framing. The question I'm asking myself is; do I go down the underpinner route, or, with training from friend, the band clamp route. I would very much appreciate thoughts. Thank you! :D
Re: Band Clamps
Post by vintage frames »
I'm assuming your friend who is a carpenter, makes his own frames from raw timber which he shapes in his workshop. After gluing and clamping up his frames, he further needs to cross-pin the mitres by hammering a long thin nail into the sides at each corner. This provides mechanical support to the glue already holding the frame together.
Because he has used raw timber, he can counter-sink the small nail head and disguise with some filler.
If you want to make the same sort of frames like he does, then a band clamp is all you need.
Buy your raw-wood mouldings from Rose & Hollis, make the frame and then paint or varnish to suit.
If, however, you intend to buy pre-finished mouldings then you really need a simple underpinner where the mechanical support is provided by inserting a steel staple into the underside joint of the moulding.
Nailing into the side of a prefinished moulding will damage and disfigure the finish.
Re: Band Clamps
What he said! There's no harm at all in learning the traditional techniques, in fact I think it's the best place to start. The main advantage of an underpinner, other than the prefinished point, is speed of working, which is only relevant if you have a workload to deal with. It's worth pointing out that if you intend to work with Oak and Ash barewoods, an underpinner takes some mastery to deal with these woods.
Re: Band Clamps
Thanks for useful and informative replies..... It wouldn't surprise me if my friend works with raw wood and, also knowing him.. he wouldn't rush... at all. :) It's all good stuff to learn that there are different ways of doing things; that way I can make an informed decision of my way forward. For now, it'll be an underpinner.... who knows for the future! Now, all I need to do is find a decent secondhand UP! :D
Re: Band Clamps
There was an absolute bargain on here recently, the Cassese 486 for £500! If I didn't already have one I'd have jumped at it.
Re: Band Clamps
Another alternative is to use spring clamps. These actually work quite well as you have room to cross-nail the
corners while clamped. That can be tricky-to-impossible with a band clamp. The one drawback is they leave a
'divot' that has to be made good, but you would have to fill the nail holes anyway. When I started off a lot of
framers I knew used them.
On larger mouldings, ( 2"+) I like biscuits in a joint. They add a lot of strength. :wink:
