Backing board while cutting mounts on Valiani mountcutter
Everybody welcome.
Postby boscawen46 » Mon Feb 18, 2019 10:19 pm
I have just bought a Valiani pneumatic mountcutter, old but working perfectly. I realise that I will need to have a sacrificial board underneath the board being cut but does this have to be repositioned often or can quite a few repeat cuts be made in the same place? Also does the "under" board have to be actual mountboard or can smooth grey backing board( which is obviously cheaper) be used?
boscawen46
Organisation: james frederick
Interests: framing,woodwork
Gunnar Computerised Mountcutters
Re: Backing board while cutting mounts on Valiani mountcutt
Postby Steve N » Tue Feb 19, 2019 9:06 am
If you have theright depth of blade set, so the tip of the blade is just scratching the surface of the under mount (better known as the slip mat) it will not have to be mover every time you cut a mount, just keep an eye on it, when you need to move it, just trim 10mm off the edge, don't forget you can rotate the slip mat around and flip it over so you get at least 4 working surfaces to cut on. If you are doing a production run, say 20 of the same size, start off loading 2 mounts in the machine, cut the top mount, remove that one, load another BEHIND the one that is on the machine, each time the one under is acting as the slip mat for the one you are cutting, the score mark on it will be within the center fall out (waste) so you are not marking the next mount at all
As to what to use, we only use mountcard, but a lot of suppliers sell 'seconds' use these, we don't use greyboard as we find it blunts the blades so quick
"Just because you seen it on the internet, does not make it true or right" -Abraham Lincoln
Postby boscawen46 » Tue Feb 19, 2019 10:08 pm
Amazingly informative response. Many thanks for that.
boscawen46
Return to General Discussion
  • Advertisement
Picture Framer's Oracle
Members Map Header
Members Map
More info
Resources Header
Contact Forum Admin
Directory
Cove Box Designer
Download Designer
General supplies
Glass
Machinery
Mounts/Mountboard
Artists
Conservators
Prints
Software
Tuition
UK Medals
Framers Forum Live!
Support Header
Crimson
White
Green
Violet
Advertise Header
Forum Banner Ads
