2 sports shirts in one frame mount issue...
FandLframes
Organisation: F and L Frames
Interests: We are in the process of buying a small framing business and we are looking for help and advice!
Post by FandLframes »
We have framed 2 very large darts shirts with photos the mount in the centre is bowing any suggestions?
GeoSpectrum
Re: 2 sports shirts in one frame mount issue...
Post by GeoSpectrum »
I did one similar a good while back, the mount was glued to foam core.
could just put a card spacer behind the center border, use white , same as the backing mount, all you need to do is add a couple dads of PVA to the edge of the sapcer, and fit it to the back of the center portion of the mount, leave it there over night and then reassemble the frame
