Adhesive Roll
GeoSpectrum
Adhesive Roll
Post by GeoSpectrum »
I’m looking for some double sided adhesive roll for sticking down paper onto mount board. It needs to be pressure sensitive, NOT heat activated.
Any recommendations?
Re: Adhesive Roll
I've used the Hotpress PMDS25082 from Wessex for cold laminating in the past. No problems with it.
StevenG
Re: Adhesive Roll
Post by StevenG »
Actually, I've had a look at that product (PMDS25082), apparently it works with MDF which sounds great. Does anyone know I could use it for mounting the cheap holiday oil paintings onto MDF. I've never had any luck with self adhesive methods regarding canvas on MDF. We usually use PVA but it takes time to and can be messy :)
Re: Adhesive Roll
There's PMSU41164 for more difficult substrates, so that might work better. Personally I vacuum press with HMFC25082.
JonathanB
Re: Adhesive Roll
Post by JonathanB »
Steven -
I've used the PMDS25082 to fix thin canvas to display board using a JetMounter and seemed to work fine. Can't see any reason why it shouldn't work on any other smooth surface, MDF included.
Jonathan Birch GCF (APF)
JonathanB
Re: Adhesive Roll
Post by JonathanB »
Steven -
StevenG
Re: Adhesive Roll
Post by StevenG »
Cheers guys, I'm going to order a roll. It sounds like a product that'll come in very handy for some jobs
Re: Adhesive Roll
I've used a pressure sensitive adhesive on a roll, basically it is a very wide roll of double sided tape, used it with manual rollers which I got on ebay, I got it from Simons,
I found for best results, apply to the paper first, then to the board/MDF, just seemed to work better way
Richard Photofusion
Organisation: Photofusion
*young, now a teenager...
Re: Adhesive Roll
Post by Richard Photofusion »
I mostly run self wound pressure sensitive adhesive, using a laminator, but I do keep a couple of rolls of the PMDS25082 for smaller jobs. I always apply to the substrate first, as this is not "a moving target".I'll use it for times when I need to know that the adhesive is in perfect condition (something that is less easy to tell with the self wound adhesives), or I can't be bothered to change whatever else is on the laminator. It is perfectly possible to apply the first coat to substrate with a squeegie, atleast if the roll is no more than 25" wide. Applying the paper, you could gently tack and brayer the the print, then apply (foam blanket and) weights, assuming the paper is paper, and not plastice coated.
Richard Photofusion
Re: Adhesive Roll
If you're not using a laminator, then twin release is the way to go - as you say, slowly and carefully. I've not seen a difference in the strength of the adhesive (with the exception of UtraTac, which I used a few years back). I've found that twin release also has a longer shelf life, before devoloping piping faults.
The top roller on our JM44 weighs 20-30KG, possibly more, so this is putting a lot of even pressure on the substrate when we prep. If the Simons board works for you, then for small volumes, I'd go with the convenience.
