Any reasonable offer considered.
Mirrors 40 x 50 cm bevelled edge Qty 100 approx
Need to clear asap.
Location West Yorkshire, Batley, WF17
Call/text Richard 0758 550 7732
- Organisation: Apexmounts
- Interests: Piano, Gym, Skiing
Re: Mirrors 40 x 50 cm bevelled edge Qty 100
Based on 6 mm mirror, that is in the 3 kg range plus the weight of the frame. I would consider those as a smallish mirror. Just about any quality "D" hook hardware with one screw will do. Just make sure that you are using wall anchors in the drywall (plasterboard) appropriate for the size of screw being used (19-25 mm long). French cleats would be overkill IMHO.
