Framing equipment - Morso EH, Brevetti S30M, Benches, cold laminator, Fletcher 2000 mat cutter PLUS (Australia)
shauntho
Organisation: Shaun Burrage - Burrage Brothers Photogr
Interests: Photography, Wilderness Hiking, Fishing
Post by shauntho »
Complete Picture Framing Setup / Equipment: (Selling as LOT, will not split)
Custom flow-through design. Includes everything you need to begin your own home-based picture framing business or hobby framing setup. Capability to build huge frames – have personally assembled frames over 2.5 meters long. 2 large custom workbenches have been designed to incorporate the mat cutter, underpinner (v-nailer) and a huge lightbox. The flow through design allows for large pieces to move efficiently and seamlessly from one workbench through a large laminator and feed onto the next workbench. The fit-off workbench has a soft felt top and provides a large area for joining long pieces of moulding to create huge frames. The cutting workbench has a translucent cutting surface - cutting blades can be used directly on the workbench surface without damaging the table! Being translucent, this cutting surface allows for the light to pass through from the huge lightbox built into the workbench. This lightbox is powered by 12 fluorescent lamps wired together in-series and is very bright. Also included is fully automatic electric/hydraulic mitring machine – 2 press-button operation. In addition, a wall mounted all-in-one board and glass cutter is included and an Exair ionizer gun and power supply (instantly removes any static to aid in dust-free laminating and frame assembly.) Other tools and materials are also included – see the list of inclusions below. Everything is in working order – inspections welcome.
Includes:
Machinery / Equipment:
• Morso Mitring Machine / Guillotine– Model EH. Fully automatic electric/hydraulic. 240V. Spare set of blades.
• Brevetti S30M pneumatic underpinning machine.
• Fletcher 2000 mat cutter.
• Neilson & Bainbridge board and glass cutter – Model BG6100. Wall mounted.
• Cold Laminator on stand. Electric (switch, foot-pedal or manual operation). 160cm roller length.
• Exair ionizer air gun and power supply.
2 x Custom Workbenches: (overall length of workspace approximately 7.5 meters.)
Workbench 1:
• Felt topped.
• Bench size: 163cm x 315cm
• Bench Height: 92cm
• 2 storage shelves under bench (each shelf 122cm x 209cm)
• Custom designed workbench includes cutout for underpinner in corner. Underpinner can be bolted into position.
Workbench 2:
• Safe cutting surface. Translucent.
• Bench overall size: 170cm x 300cm
• Cutting area bench size: 170cm x 254cm
• Storage shelf underneath (170cm x 276cm)
• Custom designed workbench includes shelf for Fletcher 2000 mat cutter.
• Workbench includes huge custom designed lightbox powered by 12 Fluorescent globes (Lightbox size: 95cm x 254cm).
Tools / materials:
• Fletcher FrameMaster point driver and box of points.
• Air gun and hoses (compressor not included).
• Staple gun and staples.
• 2 boxes of wedges for underpinner (v-nails).
• Box of mat cutting blades.
• 2 x Rolls of large felt bumpers.
• Touch up marker set.
• Corner filler/putty.
• Kevlar safety gloves and safety glasses (for working with glass).
• Surflon Nylon coated soft steel picture hanging wire.
• Crimping tool and sleeves for hanging wire.
• 2 x bags of D-rings. Small and large sizes.
• 2 x boxes of zinc plated self-tapping screws.
• 2 x Stanley knives.
• Cardboard frame corner protectors.
• 3 x boxes laminating films / adhesives.
• Large Roll of 900mm Craft Paper.
• Roll of double-sided tape.
• 8 sheets of Dibond (1.2m x 2.4m)
• Econospace clear plastic spacing strips with pre-applied adhesive.
IMPORTANT
Please note: The workbenches, mitre machine and underpinner are extremely heavy and very large. Many people, possibly a forklift and a removalist truck and ramps would be required to move it all. Also, Picture framing training not included. Selling as lot, will not split.
PRICE: AU$11,000- NEG
LOCATED: Echuca, Victoria, Australia.
Photos attached. Thank you for viewing 😊
Mebmate
Organisation: Pizienwell Arts
Interests: Chess, Landscape Gardening, DIY, Drama, Literature, Music, Tennis, Cooking
Re: Framing equipment - Morso EH, Brevetti S30M, Benches, cold laminator, Fletcher 2000 mat cutter PLUS (Australia)
Post by Mebmate »
Is this still available?
I am in the process of emigrating to NSW sometime after September 2021.
