Keencut Rondo on Ebay £50 or make Offer !!
jaybee173
Organisation: JFT
Interests: framing
Post by jaybee173 »
Looks like a bargain - located in Cannock - Price is £50 but offers invited
See it here https://ebay.to/39fdsLS
jaybee173
Organisation: JFT
Interests: framing
Re: Keencut Rondo on Ebay £50 or make Offer !!
Post by jaybee173 »
And another one based in yorkshire starting at £31 - bargains for this quality of machine.
See it here https://ebay.to/2UZb8jx
Under the fancy exterior a Keencut Rondo, is the same basic mechanism, as the Keencut Oval 6. I don't suppose that anyone even uses an oval mount cutter enough to wear it out, so The Keencut Rondo is still likely to be a very good buy, if the price is good. There are some nylock nuts underneath the table on the Oval 6 to adjest for the wear in the nylon bearings and compensate to any unwanted movement in the mechanism over time.
Any play in the mechanism is adjusted for be slightly loosening these nuts, by only a friction of a turn. I assume that this will be the same with the Keencut Rondo as on the Oval 6. At £50 quid, it sounds like a bargain for someone!
