Hi, I have now upgrade my hobby equipment to the pucker equipment... hence the sale of these items.
Thanks,
Drew
Charnwood Mitre Trimmer
The next step up from a hand mitre saw, this cast iron trimmer is used after the rough mitre to create a perfect 45 angle with the smooth finish essential for a good joint.
LOGAN COMPACT 301S MOUNT CUTTER
This mount cutter has a rigid baseboard with a spring hinged aluminium running rail. The bevel-cut and straight-cut heads fit onto that rail. Measuring and marking are made simple with a parallel adjustable back gauge, with scale and lock. An engraved guide line on the bevel cutting head tells you precisely when you have reached the start and stop lines, which you mark with a pencil. An excellent mount cutter for the semi-professional. Includes '2000' bevel head and straight cutting head. Working length: 29? / 750mm. Uses '270' blades.
FRAMECO CORNER CLAMP and PINNER
The 'Corner Clamp', designed and made in Australia, incorporates some new thinking to create possibly the best clamp of its type. Unique are the width of the back support and the specially shaped split clamping jaws. The wide back support allows moulding mouldings up to 75mm/3" wide to be joined efficiently. The many small teeth hold the moulding firmly and the split jaws flex inwards forcing the mitred pieces together. Use with PUSHMASTER or our 'SIMPLE' or 'EASY' hand underpinners
Hobby Equipment for Sale
