Hi Guys,
I'm hoping someone can help me
So ive just had delivery of an M3 underpinner (framers corner), set it all up fine but it doesn't seem to be driving the wedge all the way home leaving about 1mm sticking out.. ive set the pressure clamp correctly and the green light comes on when pinning...
so was wondering if it may be my wedges, I'm using universal 10.3mm lions/imnes ones (although the manual does say to use only framers corner ones)..
Any help from someone with experience of this machine would be great
Charnwood M3 Underpinner help
dan_kitty
- Organisation: the SHO Gallery
- Interests: Art, Animation, Motion Graphics
Sam Cook
- Organisation: Framers Corner
- Interests: .
Re: Charnwood M3 Underpinner help
Hi Dan
Sorry to hear you are having a slight issue with your M3 underpinner. If everything is set correctly, there is simple adjustment you can make for the wedge height which will insert it further into the moulding.
If you want to PM me your contact number I can get a technician to give you a call to talk you through it.
Sam
Sam
dan_kitty
Cheers Sam, sorry not been online for a few days but already found the adjustment screws and after a quick tweek all is working smoothly and I am quite pleased with it
Thanks for your help
Sam Cook
- Interests: .
That's great Dan, well done!
Just let me know if you need anything else.
Sam
Sam
