Does anyone know where I can find some black dust cover linen?
Have had to replace glass and mounts for a local art collector who bought these pieces in the US - they have been finished with this linen and would like to try and do the same.
Recall that Lion used to sell something a few years back but there's nothing in there latest catalogue?
Any ideas ?
Dust Cover
- Organisation: Southgate Studios
- Interests: Photography , Art , Art reproduction
- David McCormack
- Organisation: Framing
Re: Dust Cover
Try ooogling buckram book cloth. Don't know how you would adhere it to the back of the frame... maybe something like Evacon-R?
Here's one place that does it:
http://www.ratchford.co.uk/subcategoryd ... spx?id=224
Re: Dust Cover
I've never heard of fabric being used as a dust cover, mainly, I suppose, because most fabrics are not dust proof
In the US they use "Kraft paper" mostly but also stuff like Tyvek for higher end work. I suppose if you seal the frame up the UK (best) way then you could add a cosmetic fabric cover.
Re: Dust Cover
Thanks for the replies
Looks like this is a cosmetic touch more than dust protection.
Was looking at using a kraft paper as an alternative but will also look at the buckram option too
Re: Dust Cover
I used to be a bookbinder at one time, so I can tell you that bookcloths are starch filled to fill in any gaps in the weave, so therefore they should be completely dust proof.
Buckram is one on the most expensive varieties of bookcloth because it is produced for extended use and durability and is also dyed all the way through the fabric. Some buckrams are also waterproof on the outside face.
If you want a nice cheap bookcloth, the you might consider Reliance bookcloth which is a lighter weith fabric and is dyed only on one side.
You might like to look at Russell Bookcrafts in Thockington, Hertfordshire, or Hewit and sons in Edinborough
