rust
- Organisation: raymond bradshaw photography
- Interests: photography . Walking . travel .
rust
Can anyone recommend the best product for stoping the bare mettle on my Morso from rusting. And the best product for lubrication, without making it to sticky. Thanks for the help on my previous questions.
- Organisation: Whtewater Gallery
- Interests: Surfing, sailing
Re: rust
Hi Ray
Hope you have the hatches battened down today!
My original Morso used to rust in the shed, scrunched up silver foil did a good job for me. I can not remember which way up it needs to be though. I found the technique through good old google. If it is really stubborn then add Coca Cola I believe!
Re: rust
Pramsay13. Yes ,that sounds like a good idea. I have been looking around for some suitable mettle wax. Has any one ever used One ? Thanks.
Re: rust
Hi Nick, thanks for getting back to me. I was a bit shocked when I when out to my workshop this morning. It seams to have turned rusty over night. I will do a search on the scrunched up silver foil. Yes, we have all the hatches battened down, hell of a storm blowing out their at the moment. I am really enjoying using the gear you sold me, if I hadn't spotted your add, I would still be buying boring ready mades.
Re: rust
Glad it worked out well, hope your still enjoying it in the middle of August! For my sins we have found ourselves opening a small Gallery in Port Isaac later this week so fingers crossed that the sun starts to shine soon!
Re: rust
For surfaces not touching any of the material being cut a coat of paint is best. For pivot points a spray "moly lube" can be used. It dries to a thin dark gray film that will not collect saw dust. Check for this at a machine shop supplier. For the working surface I would use a harder wax than paste wax.... paraffin wax (a candle).
Re: rust
Nick Whitewater Gallery . You are a glutton for punishment. We feel stretched and frazzled by the end of the season, I don't think we could cope with any more pressure.In the peak period we are running around like a pair of headless chickens.
Re: rust
JFeig. Thanks ever so much for the tips. I will have a goggle around to find the products you suggest. There is always someone on here with an answer. I see your from across the big pond,are you all keeping busy ?
Re: rust
My hope is that the extra business will help to justify employing a full time framer. Note to myself.... must write an advert!
