Wireless camera
- GeoSpectrum
Wireless camera
I'm looking for a wireless camera that I can mount on the ceiling, looking directly down onto a work bench to capture images of artworks that come in. Has anyone got something like this or have any experience in using one?
thanks
thanks
- IFGL
- GeoSpectrum
Re: Wireless camera
Yes.but I also want it to capture HD video.
- JohnMcafee
- Organisation: EstLite
Re: Wireless camera
I have looked at these WiFi cameras, but am sticking with USB tethering for now.
Since I don't want a ceiling mounted appliance to rely on its battery, it isn't usually a big deal to run a USB cable along with the external supply. So I don't see any advantage for me.
Always interested to learn more about how we might use WiFi cameras though, there could well be benefits that outweigh the disadvantages.
- GeoSpectrum
Re: Wireless camera
Well a little more googling has suggested that tethering is probably better so im probably going to go for that. Which camera do you use and what is the quality like?
- JohnMcafee
Re: Wireless camera
We use a Canon PowerShot SX100 IS (among others) and have found it reliable, meeting or surpassing our quality requirements.
We've added a couple of cheap strobes to the set-up to eliminate reflections when the subject is glazed - see below.
Reflections are controlled by the use of the strobes.
- GeoSpectrum
Re: Wireless camera
Thanks John. I've decided ill use the family camera which is a little underused since the arrival of iPhones. So I have a Panasonic DCM-FZ450 at my disposal. I just need to figure out the tethering cabling, ceiling mount and software control now!
Trinity
Re: Wireless camera
I use a Canon S5 is and took a chance on ebay.
For my ceiling mount I bought a length of 28mm copper tubing, some elbows and end caps and made up a fairly rigid mount system, screwing through the end caps beofre assembly. The mount for the camers is a standard cycle handlebar camera mount.
Trinity
Re: Wireless camera
PS I also got a repeater gizmo from Maplins that extended my usb cable to 15m as I couln't get a good link with just the cable alone. It works very well.
Jamesnkr
Re: Wireless camera
Would you please explain why a strobe light reduces reflections? Surely it's the angle between the light and the glass and the camera, not the power of the light that makes the difference?
Anyway, handlebar cycle mount on way... thanks for that!
guzzijim
- Organisation: Dumfries & Galloway
- Interests: Photography, Colour Management, Sea Fishing
Re: Wireless camera
If the strobes are those in the ceiling then they look as if they are angled at 45%, the type/power of light makes little difference.Would you please explain why a strobe light reduces reflections? Surely it's the angle between the light and the glass and the camera, not the power of the light that makes the difference?
On second thoughts I would have perhaps add a diffuser to soften the shadows.
- JohnMcafee
Re: Wireless camera
Yes, we make use of a basic rule of physics, angle of incidence of a beam of light equals angle of reflection, to ensure that we do not capture the glare from the strobe reflecting off the glass. This allows us to streamline the visualisation experience for the customer by being able to photograph a framed subject without the palaver of having to deframe it first.
Also, for our purposes, there is no need to diffuse the light in order to eliminate shadows as we are only interested in the picture within the frame, and thanks to the set-up, the frame’s shadow can never fall there.
Jamesnkr
Re: Wireless camera
There's a small reflection there; you might benefit from a sheet of black card in front of the camera to restrict reflections further.
- IFGL
Re: Wireless camera
I just tried your suggestion James, I fail to see how putting black card in front of the camera can help, here is my photo, definitely no reflection though.
Framie
- Organisation: Anything Framed
- Interests: Custom Framing, Hand Finishes and Multi Aperture Mounts.
- JohnMcafee
Re: Wireless camera
Aren't you supposed to cut out a hole for the lens though, IFGL.
I've seen this notion bandied about before, however this solution only stops those reflections that would have originated from the area now covered by the card. In order to be certain of catching all possible reflections, your black card needs to be four times the area of the largest object you intend to photograph.
Re: Wireless camera
The black card/curtain method is used when photographing highly reflective objects such as silver/gold cups and trophies, basically the photographer/camera is not reflected in the object.
Jamesnkr
Re: Wireless camera
No reflection; as promised. Who is the artist?IFGL wrote:I just tried your suggestion James, I fail to see how putting black card in front of the camera can help, here is my photo, definitely no reflection though.
- IFGL
Re: Wireless camera
Not sure, there is not a signature, looks like it's about £700 worth from a certain high street gallery chain.
mho
- Organisation: Valley Photo Print & Picture Framing
- Interests: Photography, F1, Films, Music.
Re: Wireless camera
IFGL, is it a limited edition or an original ?.
