For Sale: Valiani Mat Pro 120.
It cuts superbly and is very easy to use. It takes standard size boards (not Jumbo size) and will cut board up to 3mm in thickness. The machine is "semi-automatic" it has pneumatic clamps to hold the board, the cutter head pressure on the board and the blade penetration are also controlled pneumatically. The operator simply guides the head between stops and makes a 90 degree head rotation at the corners. Search on youtube for the Valiani videos. You will require a compressor.
It will cut double mounts in one operation.
This machine also has the very useful end trimmer accessory.
It comes with a solid tubular metal stand that enables the machine to be placed against a wall almost vertically so that it only takes up about 60cm from the wall. The overall dimensions of the back board are 160 x 120cm.
This machine was made in 2004 and everything worked well before being put in storage. You are welcome to come to our shop in Stamford to see it.
Paul Mills Picture Framing
Contact: Paul Mills 07760 176906
Email: paul@paulmills.com
Reason for sale: Upgrade to a Gunnar
Price: £1000
Saffyre
- Organisation: Paul Mills Picture Framing
- Interests: Graphic Design, Picture Framing
Derek
- Organisation: Frame & Print
- Interests: Framing, Printing, Bodging
Re: For Sale: Valiani Mat Pro 120
If you have it in your shop are you able to connect PC to demonstrate it working?
Does it come with PC and software?
It's not a cmc as it says in the op
Have a look at this
http://www.valiani.com/video.php?vid=1
These are really good machines, first step on the ladder for production work
Have a look at this
- Ricky
Check Your PM.
Saffyre
Now SOLD Thanks
