New VALIANI CMC for 2016 - GLADIUS xx
- Merlin
- Organisation: Merlin Mounts
- Interests: Aviation
Valiani Srl have listened to your feedback and have now produced a new CMC.
Welcome to the new GLADIUS xx
Come to Spring Fair 2016 and see the new addition to the largest range of CMC's in the world.
D & J Simons will be showing this new machine in Hall 1 on Stand K42
John GCF
- Merlin
Re: New VALIANI CMC for 2016 - GLADIUS xx
Valiani launches the largest CMC ever built!
Introducing the Gladius 260
The largest mat cutting machine ever produced premiered at the WCAF Las Vegas show on the 25th January. The Gladius, with a massive cutting area of 1530mm x 2650mm (60" x 104") that can handle even the largest sheets of matboard with speed and accuracy, opens new possibilities for the custom framer. Valiani will be demonstrating the smaller version of the GLADIUS on the D & J Simons stand
John GCF
That is massive, but who makes mount board that big?
- GeoSpectrum
Do you still have to change heads?
My Valiani is coming up to 4 years old, so it might be time to think about up-grading, but down-sizing the remaining workbench to 2ft by 4ft
chris62
- Organisation: Sansom Gallery
- Interests: Photography/Carpentry
Crescent make that size, there is also a Guy in Germany that makes massive boards
- IFGL
My Valiani cut over 500 mounts and backings today alone, It used 1 blade to cut all the backings, 1 blade to cut all the externals of the mounts and four blades for the internals.
It doesn't use the same blade to cut external and internal cuts, the external cuts are not as critical as the internal so you get much more miles from your blades, when you get the head change knack it takes 8 seconds to change it, how long does it take the gunnar to go to the top and flip the head?
GUNNAR
In answer to IFGL's question. The F1 hybrid takes 4.46 seconds to change from 45 to 90 degrees (back again same time) The AiOX Hybrid takes 2.73 seconds. The blade usage would be about the same
Sarah/GUNNAR
Sarah/GUNNAR
And my trucut takes zero seconds as the head is already there.
- GeoSpectrum
CMC wars!
doogey
- Organisation: picture framers
- Interests: art
wow that looks great!!!! but is it really that big? or is it clever photography using Nico as he's only 3ft tall!! LOL
