New VALIANI CMC for 2016 - GLADIUS xx
Merlin
Organisation: Merlin Mounts
Interests: Aviation
Post by Merlin »
Valiani Srl have listened to your feedback and have now produced a new CMC.
Welcome to the new GLADIUS xx
Come to Spring Fair 2016 and see the new addition to the largest range of CMC's in the world.
D & J Simons will be showing this new machine in Hall 1 on Stand K42
John GCF
Merlin
Interests: Aviation
Re: New VALIANI CMC for 2016 - GLADIUS xx
Post by Merlin »
Valiani launches the largest CMC ever built!
Introducing the Gladius 260
The largest mat cutting machine ever produced premiered at the WCAF Las Vegas show on the 25th January. The Gladius, with a massive cutting area of 1530mm x 2650mm (60" x 104") that can handle even the largest sheets of matboard with speed and accuracy, opens new possibilities for the custom framer.
Valiani will be demonstrating the smaller version of the GLADIUS on the D & J Simons stand
John GCF
Post by Graysalchemy »
That is massive, but who makes mount board that big?
GeoSpectrum
Post by GeoSpectrum »
Do you still have to change heads?
My Valiani is coming up to 4 years old, so it might be time to think about up-grading, but down-sizing the remaining workbench to 2ft by 4ft :sweating:
chris62
Organisation: Sansom Gallery
Interests: Photography/Carpentry
Post by chris62 »
Crescent make that size, there is also a Guy in Germany that makes massive boards
IFGL
Post by IFGL »
My Valiani cut over 500 mounts and backings today alone, It used 1 blade to cut all the backings, 1 blade to cut all the externals of the mounts and four blades for the internals.
It doesn't use the same blade to cut external and internal cuts, the external cuts are not as critical as the internal so you get much more miles from your blades, when you get the head change knack it takes 8 seconds to change it, how long does it take the gunnar to go to the top and flip the head?
GUNNAR
Post by GUNNAR »
In answer to IFGL's question. The F1 hybrid takes 4.46 seconds to change from 45 to 90 degrees (back again same time) The AiOX Hybrid takes 2.73 seconds. The blade usage would be about the same
Sarah/GUNNAR
And my trucut takes zero seconds as the head is already there. :lol:
GeoSpectrum
CMC wars!
Post by JFeig »
Rising in the US also makes boards that size.
https://en.wikipedia.org/wiki/Rising_Paper_Mill
doogey
Organisation: picture framers
Interests: art
Post by doogey »
wow that looks great!!!! but is it really that big? or is it clever photography using Nico as he's only 3ft tall!! LOL
