Moulding
Benhen
Organisation: Ben Henriques
Interests: Fine frames
Moulding
Post by Benhen »
I've asked Norfolk Mouldings to quote for this, but if it was available off the peg it would be better. Any knowledge for something very similar? It makes an excellent frame.
Re: Moulding
It might if it had a rebate - therefore nothing similar in any framing supplier's catalogue.
Benhen
Re: Moulding
Post by Benhen »
O Roboframer, I'll take it with or without a rebate --- show me the one in the catalogue, pleeease.
In grateful anticipation....
Benhen
Re: Moulding
Post by Benhen »
For clarity, must be barewood. Thanks.
markw
Re: Moulding
Post by markw »
you might be a long time waiting for Robo's reply... try reading his post. No rebate - no moulding. You say you are having a quote - is this without a rebate or have you just forgotten it in your diagram?
Re: Moulding
I've never seen that profile for sale anywhere. Definitely a custom milling job. I'm sure there are a few folks around who would happily mill it for you.
You might want to check out timber yards around your local area. Many will have facilities for making profiles, although the choice of woods may be limited. Oak or pine usually. The expensive part is if they have to have knives made to suit the profile. Straight ones are no problem. That section needs two curved ones. It may be that some places already have knives that they use that are close enough to your design. Otherwise you are into a few hundred quid for tooling.
You could also check out the many sites that offer 'builders' mouldings. Stair parts and architraves and wotnot.
You might find something close if not exact. Most will be without rebates, but it's not a hard job to cut a rebate if you have a router or a table saw.
Nice design btw. :yes:
Benhen
Re: Moulding
Post by Benhen »
Thanks, Prospero. You have a good eye for shape. Problem I'm having with the available bare woods are they are either too ornate, or too shallow in contour for my purposes.
Benhen
Re: Moulding
Post by Benhen »
Hi Mark, thanks for the thoughts. I shall be building up the frame, which will then give me the rebate. The whole item will come out at about 75 mil in depth which is, I'm thinking, beyond the capability of most timber available to mill.
Timh
Re: Moulding
Post by Timh »
Hi Ben
i might be able to run that from cutters I have here
pm me
Re: Moulding
It occurs to me that it's going to need a fair old chunk of timber to machine it from. 3x3" or near.
With a bit of imagination you can build up a big moulding from two or more. Depending or course on the final finish and whether or not you can disguise the joins.
:lol:
Benhen
Re: Moulding
Post by Benhen »
Too many ripples for me, but awesome piece of carpentry.
Pm sent, Tim..... Fingers crossed.
Benhen
Re: Moulding
Post by Benhen »
Bet that made a beautiful frame, Prospero.
Re: Moulding
I never actually did the frame. :( I was asked to copy an old frame that was falling to bits and I did the sample more as a challenge than anything. It was a bit of a lash-up but came out surprisingly well.
I keep the chevron in the shop and wheel it out now and then to lets folks know I'm a force to be reckoned with. :clap: :lol:
Jamesnkr
Re: Moulding
Post by Jamesnkr »
Prospero, you need a ruler on that picture.
Re: Moulding
Jamesnkr wrote:Prospero, you need a ruler on that picture.
There ya go..... :D
If you look to the left you can just see the tatty old frame that I tried to replicate with the battenburg sample above. :roll:
Benhen
Re: Moulding
Post by Benhen »
God save the cream.
yankee
Organisation: framer
Interests: picture framing golf
Re: Moulding
Post by yankee »
maybe try fw Holroyd in Glasgow they might be able to help you with your problem.
yankee
Re: Moulding
Post by yankee »
