morso blade guard
red
Organisation: none
Interests: woodwork
morso blade guard
Post by red »
The morso I recently bought doesn't have a blade guard,Ive done a google etc search
re fitting a guard.there is little info on the subject I don't see how one could be fitted without drilling or large
amounts of gaffer tape-not very pretty! anyone have any advice?
thanks
MikeSwannick
Organisation: Game of Frames
Interests: All things zombie. I also do data recovery.
Re: morso blade guard
Post by MikeSwannick »
If you stand facing the Morso as though you were about to use it the guard holder is a circular metal disc about ~40mm across and ~20mm deep with a vertical ~10mm hole through it The blade guard support rod goes in there and is locked into position with a hand nut out of sight behind it that you have to reach over to locate.
Mike.
comma key still broken :xcomputer:
David McCormack
Organisation: Framing
Post by David McCormack »
This is the part Mike is talking about. I think some older Morsos don't have this fitted and you may need to buy this bracket, but I'm not sure?
From the Lion website:
"On newer machines, it slides into a hole in the top casting. For older machines, you will need to buy the fixing bracket, Part no. DAN0005."
Chris2103
Organisation: Chris Lordan Photography
Interests: Photography: social, landscape, product, wildlife. Hockey. Framing my pictures
Post by Chris2103 »
I think Lion sell a clamp on bracket for older machines that do not have the holder fitted
https://www.lionpic.co.uk/p/14730/Clamp ... -box-guard
red
Organisation: none
Interests: woodwork
Post by red »
many thanks for that I will check out lion ,it doesn't appear that
clear in their description
regards
