Dried blood on museum board
Bagel Framer
Post by Bagel Framer »
I've managed to get some blood on a museum mount that I've cut. While I'm not averse to buying another board I was wondering if anyone has any tips on covering up the blood?!!?;
Framie
Organisation: Anything Framed
Interests: Custom Framing, Hand Finishes and Multi Aperture Mounts.
Re: Dried blood on museum board
Post by Framie »
That's a hard one, normally fresh you can use your saliva to clean it up, dry it and use dry cleaners sponge/rubber to clean any marks left.
Not sure if it works as well when it's dry.
Anything Framed
Bagel Framer
Thanks.....
I've tried a wet wipe and that wipped it off beautifully.
Will see how it dries, but it looks fine at this early stage.
Framie
Post by Framie »
That's good.
Anything Framed
pramsay13
Post by pramsay13 »
I have a box of plasters on my workbench, just in case.
I've got blood on mountboard a few times, but thankfully never on any artwork.
Jamesnkr
Post by Jamesnkr »
+ steri strips; they're a bit expensive but not as expensive as lost time. Insulating tape I find to be very good for taping up small cuts as it doesn't leak.
caro
Organisation: Manor Farm Studios
Interests: making stuff with wood, glass, metal, textiles, paint. Big friendly dogs.
Post by caro »
Marks on rag board can be sanded off with a very fine grade sandpaper, then burnish down the fluffed up area with an agate burnisher,
Practice on a scrap first to perfect the amount of pressure with the sandpaper and burnisher and to make sure the sandpaper doesn't leave a mark,, It's also possible to scrape the surface of mountboard with a sharp razor blade, the back of a teaspoon can also be used as a burnisher but again test on a scrap first to make sure it doesn't leave a mark. Obviously blood may have soaked in beyond the mountboard surface but I hope the above may be useful !.
Caro
