Clamps
The Common Framer
Organisation: The Horsell Framing Company
Interests: Photography, Boats
Clamps
Post by The Common Framer »
Hi all
Occasionally I have an issue where by deeper rebate mouldings - pinned and glued using wedges - remain slightly open at the face and require taping until glue dries.I am looking for a good clamping system that can hold the mitres together instead.
Anyone use the following? Any good?
Any other suggestions welcome
many thanks
Re: Clamps
Post by vintage frames »
Strap clamps are definitely the way to go but the Frameco seems a bit expensive. I use loads of these -
https://www.axminster.co.uk/multi-angle ... amp-910142
Jules007
Organisation: Fisherton Framing
Interests: Photography, Art, Engineering, Travel
Re: Clamps
Post by Jules007 »
I use the Frameco clamp. Yes it is a bit expensive, but it has a steel band instead of a strap so doesn't stretch and feels really solid when it's pulling a frame together.
fusionframer
Interests: framing
Re: Clamps
Post by fusionframer »
I have axminster ones and they work for me. I only use for exact reason you gave when i have pinned frame but need to pull top tighter and these work well for that.
If i was gluing a frame without pinning, then i would use frameco, but i do always pin, so axminster ones are fine.
This is what works for me anyway.
Nick
www.fusionframing.co.uk
Re: Clamps
I agree that the Framco will give a stronger clamp but unless you're trying to create nuclear fusion at the joints, the Axminsters are more than adequate for the job.
Re: Clamps
I have a second hand frame co, I glue and clamp then underpin while clamped. It's a great tool.
The Common Framer
Re: Clamps
Thanks all for the advice. Will buy one or the other! Probably frameco as it looks more robust but will see.
cheers
David McCormack
Organisation: Framing
Re: Clamps
Post by David McCormack »
You'll enjoy having a strap clamp in your workshop, I couldn't do without mine. I've a collection of clamps including a steel one which I find a bit unruly... it seems to have a mind of its own :shock: but you can play a lovely tune on it when tensioned :lol:
I favour the Bessey BAN700 and don't have a problem with the strap stretching... but it does play a much lower note when you twang it!
Re: Clamps
There are the good old framers spring clamps which were widely used before underpinners became available.
They are very effective, but do leave divots which you have to make good. OK if you're hand-finishing.
But on deep mouldings it's often necessary to cross-nail the tops, so you already have a hole to fill. :)
All-in-all I think the strap clamps are the best solution. Trouble is, if you are doing lots of frames you need lots of clamps
which is not really on.
Only other solution is a dovetail joiner. Worthwhile investment if you are doing deep frames on a regular basis.
Re: Clamps
*** Stanley used to do a very useful strap clamp. Just a ratchet mechanism and webbing. I have a few and use them
all the time. Fortunately they don't really wear out and the webbing is easily replaced. Wish I could bouy some more though. :|
There are tie-downs that are made for strapping things on trailers and wotnot. They are OK but a bit complicated.
Re: Clamps
I've got one of the cheaper ones with the nylon fabric band as opposed to the expensive one with the steel band. I've no idea if it's the same as the Axminster band clamp, or not, but It is more than adequate for getting the job done. If I am using deep mouldings, I like them to be deep enough to be able to get the band clamp around the frame, but without the band clamp preventing the frame and band clamp from being placed onto the underpinner for joining. For this to work the band clamp needs to clear the fences on the underpinner. Hence the need for deep enough mouldings.
I don't wait for the glue to set, before underpinning, but I don't stack wedges anywhere near the outer edges (or back of the frame), as this can result in gaps in the outside of your mitres. I would add that some of the closer grained hardwoods, such as walnut can be a lot harder to get a nice mitred neat result and can be difficult to predict when a nasty mitre joint will appear and it can be expensive when the last mitre on an expensive frame goes badly wrong with no warning and much of that frame may become waste.
fraggle
Organisation: Perfectly Framed
Interests: Gardening, tennis, DIY
Re: Clamps
Post by fraggle »
David McCormack
Re: Clamps
The Bessey's are cheaper in my link above :wink:
Jules007
Re: Clamps
Post by Jules007 »
Although I use a Frameco like the one above, I've just ordered one of these as well:
https://www.amazon.co.uk/Stanley-ST0831 ... B001DZVNE8
For the price it's worth a try.
Re: Clamps
This is the clamp I mentioned. I post it merely as a matter of interest as like all really useful gadgets, they don't
make them any more. :lol:
Really simple and elegant design. Tough as old boots. It's cinched up by a spanner which means you can get some serious
wellie on. No sticky-out bits; you can strap something and put it in an underpinner with the clamp on. If the webbing gets torn
you can fit new. Or extend it to any length. Beautiful. :D
If anybody comes across any on their travels I would be grateful if they could steer them in my direction. :ninja:
Re: Clamps
I'm much in favour of the basic ratchet straps much like Prosperro has been mentioning and posting a picture of. To be honest they are nothing special, just a simple and versatile way of doing what needs doing. I've bought a few, rather basic ratchet straps over the years from my local hardware shop.
I had some of them for longer than I care to remember. They are just your basic imported cheap and cheerful Blackspur ratchet straps. Do they stretch a bit? I would say so! Does it matter? Not a lot! Still gets the job done.
From memory, I think my first ones were £2.99 each, but a while ago now. I don't think that you will be paying anything that will break the bank even now, probably still less than four quid. How can you go wrong?
Chris2103
Organisation: Chris Lordan Photography
Interests: Photography: social, landscape, product, wildlife. Hockey. Framing my pictures
Re: Clamps
Post by Chris2103 »
Prospero they do ratchet webbing straps in Halfords. They have the ratchet handle to tighten the webbing with.
Re: Clamps
Chris2103 wrote:Prospero they do ratchet webbing straps in Halfords. They have the ratchet handle to tighten the webbing with.
Yes I've tried them. Problem is, are quite complicated compared to the Stanley ones. The lever mechanism is cumbersome and you can't
get the same tension on as with a spanner.
Re: Clamps
Justintime wrote:I have a second hand frame co, I glue and clamp then underpin while clamped. It's a great tool.
Having said that, I've recently got hold of a hoffmann mu2 dovetail router, which means I've not used the clamps recently.
Hoffmann have just made available a W0 router bit and keys too, for tall thin mouldings.
louisesimon
Organisation: Peckham Pictures (closed)
Interests: Framing, Art, Photography
Re: Clamps
Post by louisesimon »
justintime do you have a link to the W0 router bit? Thanks
