Hello,
I am looking for a bare wood L shaped/tray moulding into which a 3.7cm deep canvas (60 x 60) fits so its flush with the top of the moulding.
Does any one know of one please?
Or does anyone who makes them from 2 lengths of flat moulding be able to advise me please?
The customer wants them flush and unpainted so minor imperfections cannot be hidden - it may be an impossible task???!
Sarah
Searching for a L shaped moulding
- Organisation: Fellows Framing
- Interests: Framing, Riding
Re: Searching for a L shaped moulding
Hi Sarah -
Lion L2023 (p179) might work - it has a 42mm rebate but with a suitable 5mm spacer behind the canvas could be okay. I've used it before and it cuts and joins well.
Good luck
Jonathan
Good luck
Jonathan
Jonathan Birch GCF (APF)
D & J Simons do one http://www.djsimons.co.uk/index.php?rou ... emb%2F0008
it can be cut either way , so the depth is either 22mm or 36mm (my sample is a whisker over 36mm)
- GeoSpectrum
Lion 2023 with a spacer, works every time.
- GeoSpectrum
Thanks guys.
Lion moulding with spacer will do nicely - why did I not think of using a spacer???!? So logical when you know.
Sarah
Sarah
- Skinnymarinky
- Organisation: Zinc White
- Interests: Painting, Drawing, Sailing, Cycling, Re-using old materials - creatively.
Try these
https://www.lionpic.co.uk/supplies/fram ... s-offsets/
For anything in between the offset heights, pack out/up with a tiny square of card.
