Gesso alternative for decorative elements
Everybody welcome.
Postby josvanr » Thu Feb 14, 2019 12:10 pm
Hello
I'm looking for a suitable material to form decorative elements of on my frames. What I image is a material that can be processed similarly to silicone putty, ideally dispensed from a tube. It should set hard enough (unlike acrylic or silicone putty), but not too fast. Any ideas?...
Jos
josvanr
Organisation: jos van riswick, artist
Interests: traditional painting, making frames, classical music
Gunnar Computerised Mountcutters
Re: Gesso alternative for decorative elements
Postby vintage frames » Thu Feb 14, 2019 2:00 pm
Hi Josvenr
I'm assuming you want to add the fiddley bits you see around antique frames. The usual way of making these is from a mould where the casting material is pressed in and so takes up the shape required. This is then glued onto the picture frame. If however you want to create your own shapes or patterns, then you would need a modeling material. And there it would be best to talk to your local supplier of Plaster Casting and Modeling Supplies.
The traditional and most user friendly method of casting these patterns is using a material called composition. This is a mixture of hide glue, roisin, linseed oil and whiting. When warmed this becomes highly flexible and elastic and can be squished into any shape or mould. Then as it cools, it becomes quite stiff and eventually very hard if left overnight. Its advantage is that it is easily shaped to fit the frame and will accept water laid gilding. If you do opt for a synthetic modeling material, then that advantage will be lost. Also composition is very cheap to produce compared to synthetic alternatives.
We can discuss formulas and methods further if you wish to explore the traditional route.
Organisation: gilded frames
Postby prospero » Thu Feb 14, 2019 2:19 pm
There is some stuff generally termed 'Pasta' in the trade which is fine wood dust combined with a binder and solvent.
There are still some plain wood mouldings available with running ornaments applied using this substance. I've used a lot
of these mouldings over the years and it's easy to paint. I bought a huge tub of it many years ago and even though it eventually
went solid I used to saw a chunk off and add Acetone to revive it. Very handy for frame repairs and filling holes, etc.
I also had some ready-cast ornaments made from it and one of it's useful properties was that it could be softened like
gesso composition by the application of heat.
Unfortunately, like a lot of very useful things it doesn't seem to be made any more. :cry:
I've tried mixing my own. No shortage of wood dust. Acetone easy to get. But the binder is more problematic. I've tried a few things
but none replicates what goes into the stuff I originally had.
If anyone knows the recipe I would love to know. :clap:
Alternatives that may suit your needs are Two-Part Wood Filler.....
and a cold-set modelling clay such as DAS Pronto.
Both these set hard and can't be softened once cured.
Sorry for the lame answer. :roll: You know as much as I do now.
Postby JFeig » Thu Feb 14, 2019 2:42 pm
Compo (composition) is the only way to go if you have a flat pattern and want to have it conform to corners or curved surfaces.
BTY, there is a company in Chicago that has been in business for about 140 years that has their original hand-carved patterns from when they opened in the Victorian era. https://decoratorssupply.com/pages/company-history
https://www.youtube.com/channel/UCOvSeSy5AJIEi_B3XwbhCUg/videos
Postby vintage frames » Thu Feb 14, 2019 5:50 pm
Indeed I remember buying a tub of pasta and some acetone. Like that of Prospero's, it solidified in the tub. What I do remember was how expensive it was. I guess you could make something similar with wood dust, whiting, Titebond glue, a little vegetable oil to soften it and either acetone or meths to keep it wet. But why bother when if you make a cake load of compo, hack off what you need and keep the rest in the freezer.
Mind you, Goldleaf Supplies sell it ready made -
https://www.goldleafsupplies.co.uk/gilders-compo/
Postby josvanr » Sat Feb 16, 2019 10:37 pm
Thnx those are some useful starting points. I also thought of the 2 component wood filler, but hmm a bit pricey... The 'composition' was what I was looking for I think. Will investigate this further !
josvanr
Postby prospero » Sun Feb 17, 2019 12:34 am
The 'compo' way is the time-honoured method. The ornaments are cast and then steamed to soften them so they can
be applied to a frame. It does require a bit of preparation and you have to 'cook' it in a double boiler and use it pretty much
there and then. Not quite so convenient as taking a lid off. :lol:
Postby vintage frames » Sun Feb 17, 2019 12:04 pm
The way you do this is after you've made your bowlful of compo, divide it up into 5 or 6 small cakes and wrap each of these in clingfilm. Then you can put them in the freezer where they'll keep for 6 months or more. When you need to use some compo, then all you do is take some out, warm it up in a low heat microwave, squish it into a mould, let it cool and there you go - a perfect ornament.
I usually let mine cool for an hour or so before painting the backs of the ornaments with dilute PVA and sticking them onto the frame.
Return to General Discussion
  • Advertisement
Picture Framer's Oracle
Members Map Header
Members Map
More info
Resources Header
Contact Forum Admin
Directory
Cove Box Designer
Download Designer
General supplies
Glass
Machinery
Mounts/Mountboard
Artists
Conservators
Prints
Software
Tuition
UK Medals
Framers Forum Live!
Support Header
Crimson
White
Green
Violet
Advertise Header
Forum Banner Ads
