Removing double-sided tape
- Rainbow
- Interests: varied
I got a print to re-mount and frame. The existing mount has been stuck to the print with double sided tape. I've managed to remove the mount but it's left a sticky residue on the print. Does anyone know if there is a safe/foolproof way of removing the residue?
- David McCormack
- Organisation: Framing
Re: Removing double-sided tape
This is the stuff you want https://www.lionpic.co.uk/p/9699/Zest-I ... aner-125ml
Trying to remove anything like sticky glue from paper is never really safe or foolproof but this stuff will be your best chance.
Another option is not to remove the glue and cover it with a dusting of french chalk.
- StevenG
Lighter fluid can work most times, if it's possible though I'd try a little on a test area first
Be careful. Yes there will be a solvent that will dissolve the glue but remember that applying the solvent could easily spread out the glue and have it re-dry into the paper. If the print is valuable, then it's really a job for a paper conservator. Or you could just attach some acid free tissue to cover the stains or do as the previous post says, sprinkle with some talc.
What you have to ask yourself is: Are you a framer or are you a restorer?
Best to take what you are given and frame it rather than try to 'improve' it. You can come seriously unstuck.
caro
- Organisation: Manor Farm Studios
- Interests: making stuff with wood, glass, metal, textiles, paint. Big friendly dogs.
I did not get on well with zest. Lighter fluid I've used many times, for masking tape, sellotape, self adhesive stickers on the back of photos, stuck down pictures, etc. for items which are not of high value. Obviously it's not the job of a framer to interfere with the artwork so I first suggest to the customer that they go to a conservator, if they say they don't want to, I offer to remove the tape with lighter fluid explaining that it is not the proper way to do it, so they have the option.
It's adviseable to work in an area with excellent ventilation but if you have any breathing isssues you probably shouldn''t do it.
Test a small area first.
- Rainbow
- Interests: varied
Many thanks for all these suggestions. I tried lighter fluid which I had to hand, and that's done the trick
