Massive Mouldings
Re: Massive Mouldings
Post by vintage frames »
That's a really good investment. You can do so much more with a table saw. As long as you keep the blade sharp and don't overload the motor, then that saw should last a good few years. As I said, if the blade is sharp, then you don't really need the higher toothed blade yet where the benefit only shows when trying to push through a higher volume of timber.
cleaver
Interests: .
Post by cleaver »
Great tip on the saw, Mark.
I got a sliding mitre saw very cheap recently - for building, really. But I might look into the 36 tpi as an option if I ever need to cut any big mouldings.
Hope the shop re-opening went well, mate....and that it didn't take too much out of you.
Thanks for asking. Well it didn't go quite as well as I hoped. I tried to cut some glass, but did not realise just how difficult it would be after my stroke. I just don't have much feel to get the pressure and the action right. The first piece of glass ended up in the bin and the second piece was a bit rough and needed the cut cleaning up on the bench top mounted belt sander to look presentable.
Frankly I was not expecting cutting glass to be much of a problem, but it was unfortunately. I've got a System 4000 wall mounted cutter and I'm wondering if a new glass cutting wheel might make up a little for not very consistent pressure and action. If I can find enough scrap glass to practice cutting maybe I'll get better.
cleaver
Interests: .
Post by cleaver »
You'll get there with it, Mark.
I can't imagine how frustrating it must be to re-learn stuff we all take for granted.
Everyone on here is rooting for you....and admires you for your guts and stoicism.
Keep at it, fella - but please take it steady and listen to your body.
:clap:
