2 things...canvas backing and which underpinner?
Just Love Art
- Organisation: JL Art
- Interests: Framing & art loving.
How do,
I have a chance to buy an Alpha machine 1M foot operated underpinner for around £260.
I only have a small portable Logan which has done well.
I’m wondering if this new machine is worth it or if I should get something pneumatic instead, any advice or help would be greatly appreciated?
Secondly I’m trying to find some black backing material for canvas frames. I’ve used felt before but it’s too thick can anyone offer any suggestion of what to use and where to find it?
Many thanks in advance.
Leo
odocat
- Organisation: Tobi Frames
- Interests: Picture framing
Re: 2 things...canvas backing and which underpinner?
If you can go for a phnmatic machine. We are all getting older and foot operated machines are not good for knees and hips in the long run.
- GeoSpectrum
Can you explain the backing for canvas frames. I'm not sure what you mean?
Not really an advert or a want as such so moving this topic to General Discussion.
Just Love Art
Hi yes, I recently changed a framed canvas for a customer and the back of the whole thing was covered in a black material (not felt, it was thinner) it wasn’t see through either and hid all the z clamps, tape and inner joins and was stuck on by double sided tape and a neat hole cut for the middle canvas. I’ve searched and cannot find the same material. I’m guessing it could be something else repurposed for this but wanted to ask in case it isn’t.GeoSpectrum wrote: Fri 29 Nov, 2019 8:53 am Can you explain the backing for canvas frames. I'm not sure what you mean?
Leo
I can highly recommend a Cassese CS88 and you can pick one up for the same price if you're lucky. It will be far superior to the M1 imho.
Never seen or heard of a black frame covering, other than paper.
fusionframer
- Interests: framing
I have had something to reframe which had a similar covering. Looked almost like roofing membrane material.
Certainly not purchased from a framing supplier. My canvases are always left with no backing. I would suggest to your customer it does not require a backing. If they are insistent, a trip to travis Perkins or some similar place will be needed, but they tend to be rather big rolls.
Good luck
Nick
Good luck
Nick
Had the painting come from the US by any chance? It's a convention there to cover the backs of canvas frames with a
sort of material that may very well be a building industry membrane. I suppose it neatens up the back a bit but it really
is unnecessary IMHO. All I do is paper the back of the frame with brown gumstrip, but I never lap it over the canvas.
*** Edit. Goole "Tyvek"
Black garden fleece? Probably would look the part and does not cost too much and you don't have to buy it in a large quantity.
https://www.amazon.co.uk/Non-Woven-Gard ... 33&sr=8-33
Years ago, the back of a canvas sometimes used to be covered with brown paper. I don't think anyone bothers about it these days. There was not any particular requirement to do it, probably to keep out dust and spiders. Not really anything of great consequence.
Covering the backs of frames like this tends to be something which is more popular in the USA. I far as I understand, the usual approach is to stick it to the back of the frame, rather than the canvas. It's does not appear to be something reserved for canvases, but more generally something that they do, where as in the UK we use backing boards and seal the backing board to the back of the frame.
If you are really into presentation, something black covering the whole of the back of a finished frames, with some nice stranded stainless steel wire, or stranded brass wire, takes a lot of beating when it comes to looking good and help to justify the prices that they charge. It's not a bad idea when you think about it. The idea of doing something similar has crossed my mind at times. Done properly it looks really classy!
fusionframer
I guess it would look neat, but not serve a purpose as it will not be seen once hung. I, like prospero tape the frame, but avoid canvas.
Also, 3 artists i frame original oils on canvas write a description in pencil on the back of the canvas, so want it to be seen.
I use offset fittings for canvases and measure where they are fixed so all are directly opposite so i think that leaves a neat finish.
Nick
Nick
