I recall someone asking about deep rebates for frames.
I am having to do a very deep rebated frame for a rugby shirt with a cap. I started today so thought i would take a few pics as i go.
I am using R&H A344, a big chunky moulding with a decent rebate anyway. So first i make and pin the frame
When i cut this frame, i cut a 2nd one exactly the same size. This one i run through the bandsaw. I not only remove the rebate, but cut back about 10mm into the frame itself.
I then pin this together and as i have the time, glue and clamp the frames together. If i had less time, i may have used some pocket screws.
So i now have a rebate for the glass, i will use the leftover piece when cutting the 2nd frame (photo 2) to fit to hold the glass in place and have a 2nd rebate for the mountboard with shirt and cap to sit giving me 33mm clearance from the glass
Will update hopefully tomorrow.
Nick
Deep rebate frame
fusionframer
- Interests: framing
Deep rebate frame
Re: Deep rebate frame
That's the ticket!
I found a nice way of blending the two on the outside edge. There is always a bit that stand proud no matter how
accurate you think you have cut. Use a piece of scrap glass to plane it. Better than sanding. One side of the glass
will be sharper than another. Got some pieces of scrap glass have you?
fusionframer
Thanks Prospero,
Gave it a go and it worked well as you said, then realised i use cabinet scrapers which is what the glass is acting as so used that. Happy with results
I then took the rebate off the remaining part from the 2nd frame and cut them to fit the lower rebate and fitted in. I decided to not trim the depth so that will give me 44mm of clearance from glass to mountboard.
I am having to wait for customer to come back to decide on frame colour, but just finishing off as normal. I have put an offcut of mountboard so i can place items in position.
Wow, I've just found my up to date Rose & Hollis catalogue and seen what size the mouldind is. That's an impressive substantial looking frame. I like frames of generous proportioned mouldings, great idea!
Frangipaniframer
- Organisation: Bell Fine Art
- Interests: 1940-50s fashion, lifestyle and memorabilia. Sewing, crafting, and of course picture framing
I’m so happy that I found this tip today! It works a treat!prospero wrote: Sun 08 Dec, 2019 2:10 am That's the ticket!![]()
will be sharper than another. Got some pieces of scrap glass have you?![]()
Fran Howson GCF APF
