Oversized Mount/mat boards
customer just brought in a picture 150 cm x 60 cm, and would need it mounted with borders of 10cm
so roughly 170 x 80 cm, 67" x 31.5"
the question is, are there large format museum or conservation quality boards available in this size? and who would be able to cut it?
I have had this prob before and I could not find a board bigger than 60" in the U.K. Even if you could, you have the logistical prob of actually getting the stuff to your door undamged. Sending a couple of sheets by carrier........ I don't think so.
The biggest manual moutcutters will take a 60" board but in this case you need to do a 60" cut. Not sure if any CMCs will do a window that big (??)
One idea.
Rose&Hollis do a flat moulding with a bevel. (refA231). It's only 70mm wide though. But you could make a 'mount' using this moulding and panit it. Cover the back with barrier board.
Best I can come up with.
One idea.
Have you checked with either Nielson Bainbridge or Crescent - they both have distribution in the UK. They both have 48x96 4 ply rag in white, at least here in the US.
Bainbridge items
8661 = 48x72
8662 = 48x96
Crescent items
2263 = 48x72
2273 = 48x96
8661 = 48x72
8662 = 48x96
Crescent items
2263 = 48x72
2273 = 48x96
cutting an aperture (window) in any board that is larger than the capacity of a mount (mat) cutter is done by dis-assembling the cutter. The bar and cutting head are positioned for cutting. A second framer holds the bar in place (or clamps) while the cutting head is operated by the framer in the normal fashion. I cut from the verso side (back) just as when using a fully assembled cutter. Don't forget to place a scrap sheet under the board where the cutting is being done. If 2 positions are necessary to cut a single line, I dip the blade into the first cut to position the board to the cutter(alignment) prior to clamping and cutting.
When oversize mounts are required, we achieve a similar result to Jerome but without the inconvenience of dismantling the machine.
We use a heavy 48 inch engineers' staightedge and a Logan 2000 hand-held mountcutter. The straightedge can be slid along a pencil line as needed, whilst the Logan remains engaged in the board. It is helpful to have two people on this job, but I have done it single-handed. Any length can thus be cut.
The resulting bevel is indistinguishable from a machine-cut one.
Dave
Dave
I've done it that way, but it a PITA to do, like never again if it's something massive. These days I avoid stuff like that.prospero wrote:Rose&Hollis do a flat moulding with a bevel. (refA231). It's only 70mm wide though. But you could make a 'mount' using this moulding and panit it. Cover the back with barrier board.
John's (Robo's) suggested pack of 25 sheets jumbo mountboard would make life a lot easier if you've got the space to cut a mount that big. The remaining sheets could be cut up for normal stock after you are sure you won't need them.
ooh good idea John, shall mention it to the relevant parties. of course its going to be hideously expensive no matter what course of action we choose,Roboframer wrote:Another option would be a splicing and fabric wrapping, Grahame.
although i get the feeling the customer won't like the price we give him.
- gesso
- Organisation: The Gilders Studio
- Interests: see above
on the occasion when a customer has contacted me with this size of mount required ive given them the option of using a wooden mount covered in paper / thin card. Rose and hollis do a slip- like moulding that once chopped and joined has the profile of a beveled mount all thats left to do is either paint it or cover it in fabric or paper. Cutting a large mount in the way suggested earlier IS a two person job. Ive been doing this for twenty years now and if pushed will just abount manage it on my tod
According to the people who know much more than I will ever know, 2 ply is not enough separation. You really need 4 ply minimum.
Another lurk you could try which would offer better protection than 2 ply is to use Mylar/Melinex for the barrier. Very thin and totally impervious to acid.
No matter what you use, you still can't stop the 'outgassing' from wood in the frame package!
