Misbehaving point driver
Trecelyn
Organisation: Orchard Street Framing
Interests: Defying gravity, playing music
Post by Trecelyn »
My point driver (Inmes FI-150) has decided to only fire points one in every 4 or 5 trigger pulls. This is despite using their own 15mm points. They seem to jam on the second or third trigger pull.
Is there a remedy or should I get a new one?
Thanks in advamce
T.
Re: Misbehaving point driver
Post by vintage frames »
This is most likely being caused by the front edge of the firing pin becoming worn and skidding over the points cartridge. If you are able to do this - take out the firing pin, turn it around and re-assemble. The new edge should now engage with the points.
Having said that, they're not too expensive to replace.
Trecelyn
Post by Trecelyn »
Thanks for the tip!
Looks like a new one is in order.
The firing pin is welded to the spring holder.
Another lesson learnt!
T.
