2mm or 3mm glass?
Rainbow
Interests: varied
2mm or 3mm glass?
Post by Rainbow »
I've been asked to replace some glass, which is 950 x 350. I haven't yet seen the job. I think 2mm glass is probably OK but because it's a bit long and narrow, I thought I'd check with the experts whether 3mm glass would be better. Thanks.
Re: 2mm or 3mm glass?
I wouldn't give it a thought to use 3mm on that size, 2mm is fine :sweating:
Rainbow
Interests: varied
Post by Rainbow »
Thanks Steve. I thought it would be but sometimes you doubt yourself (or at least I do!) :)
I don't not know were this comes from, but I understand that 2mm is spposed to be O.K up to 1 meter square, so I'm say 2mm is O.K., but 3mm won't do any harm either!
Rainbow
Interests: varied
Post by Rainbow »
Thanks Mark, I'm going to stick with 2mm :)
2mm glass is fine. 3mm may be a tad stronger, but it would be 50% heavier. :?
Rainbow
Interests: varied
Post by Rainbow »
Thanks for another vote in favour of 2mm, prospero :)
2mm bends more easily than 3. :D
pramsay13
Post by pramsay13 »
2mm will be fine but I start to think about 3mm once the piece of glass to be cut is longer than the 914mm width of the glass sheet.
I don't know what the maximum size is for 2mm water white glass, but it is definitely less that normal float glass! Normal float glass has added iron and that adds extra strength, it also adds a slightly green tint to the glass. Some specialist glasses are 2.5mm thick, I am guessing that this has something to do with how much less strength water white glass has to offer, but I have not seen anything official about this.
I would be happy to use 2mm glass on any size. :D
David McCormack
Organisation: Framing
Post by David McCormack »
2mm glass for me :yes: but I do think it makes a difference on how the glass is held in the frame. 5mm spacers will offer less support than say a wide window mount!
That's interesting Mark, just looking on the Wessex website, I see they only do 3mm WW glass now... I'm sure I used to order 2mm WW glass? :shock:
I did not know about the 3mm water white glass. Every day is a school day!
Mebmate
Organisation: Pizienwell Arts
Interests: Chess, Landscape Gardening, DIY, Drama, Literature, Music, Tennis, Cooking
Post by Mebmate »
I have heard that Wessex's supplier of the 2mm WW has closed down. Unknown whether this is for good or not.
grahamdown
Post by grahamdown »
anyone know of another source of 2mm water white glass - I use quite a bit of it and running low on stock now!
