I have purchased some single sided silicone release paper, Unfortunately not sure what side to face up or down, Have spoken to Lion and they suggested to try a small piece on a gash print using either side. Tried this and both sides worked . I am anxiousness that it may react on certain papers .
I did order incorrectly a couple of months ago. So a little late to send it back. Stock no. 9629.
Jon
Sealion silicone release paper
Re: Sealion silicone release paper
Is it not obvious which side is silicone and which is paper?? You could try sticking a piece of gummed tape to both sides?
- Organisation: Forge Framing Studio
- Interests: golf music reading drinking wine and eating fresh food
unfortunately both sides look and feel the same, tried tape both sides do not stick . as i said i even used both sides in the Hot Press both worked,
bit of a head scratcher ?
Best
Jon
Best
Jon
Lucky for you it sounds like it was mispackaged!
Hi Justin
I think you are correct, i have been playing around with the release paper this morning and it works perfectly well on both sides.
cheers
Jon
cheers
Jon
