Deep Box frames
Deep Box frames
I usually like to make my better quality box frames using Simons moulding 000K/0114. The wood grain shows nicely through the paint and looks quite classy. I sometime make up cheaper box frames by converting ready made frames which have been hanging around too long without selling, by adding a simple rear box section inside the rebate and securinging it in position with multi-tab and screws. I always charge much more for the box frames where it is all one moulding. Letting customers see both versions often help to convince them to spend the extra on the better looking single oulding version.
framefreakuk
- Organisation: FrameFreak
- Interests: Picture Framing, art & design, fitness, dogs & cats, children!
Re: Deep Box frames
Thanks for this. I need to create a depth of 115mm....so have seen posts about stacking frames on top of each other? I don't have a bandsaw though which I imagine would be needed to remove the rebate from the lower frames. And I would think there would be "joins" along the edges of the frame?
I would like to become skillful in making these very deep box frames because as you say, there is a definite market there. I feel a course coming on! Perhaps I will post that as another enquiry to see if I can find one near me in Surrey....
Re: Deep Box frames
115mm is very deep for a box frame. You either have to contend with the big gap between frame and wall or conceal
the gap with a deep moulding. The trouble with the latter is that it can look like a big lump on the wall, depending on
where it is hung. On a small frame it can look like a fire alarm switch.
One way of building a deep frame is the get a wide, flat moulding and mitre it at 90º - that is with the rebate pointing up.
When joined, this forms a little shelf that another moulding can drop into. It does mean a bit of fabrication with spacers
to retain the glass, etc. Not really an option for a 4" deep box though....
IMHO both a huge "slab-sided" frame and a "floating-off-the-wall" frame look better than something between the two.
framefreakuk
Re: Deep Box frames
Thanks so much Prospero. I am now wondering if I could do a frame within a frame, creating the max height with spacers etc. and then using a double mount to hide all the internal fixings..... The customer is happy for me to flatten the hat as much as possible so we can get the overall height down too. So I should be left with a stepped slab sided box. Wish me luck!
framefreakuk
Re: Deep Box frames
I've just realised this may be the "something between the two" option that you mention.....
- Tudor Rose
Re: Deep Box frames
If you use A333 Obeche from Rose and Hollis, it is designed to allow for extension pieces such as A335, A337 and A339 (all in obeche) to be fitted into the rear of it. They extend the rebate in a variety of size depths, which should give you the clearance you need. Fill and sand the gap once it is slotted together, then add a paint finish and the join becomes invisible in a substantial and solid looking frame. No other woodworking tools required.
We've framed baseball caps and cricket caps (as well as many other 3D items) in this moulding very successfully. It can be deep enough to sit independently on the floor or a shelf/table if they don't like the look of such a deep frame hanging on their wall.
framefreakuk
Re: Deep Box frames
Thank you Jo, I will look into these - sounds like a perfect solution.Tudor Rose wrote: Thu 17 Nov, 2022 12:45 pm If you use A333 Obeche from Rose and Hollis, it is designed to allow for extension pieces such as A335, A337 and A339 (all in obeche) to be fitted into the rear of it. They extend the rebate in a variety of size depths, which should give you the clearance you need. Fill and sand the gap once it is slotted together, then add a paint finish and the join becomes invisible in a substantial and solid looking frame. No other woodworking tools required.
