Probably should have said a big fat NO
Gesso&Bole
Post by Gesso&Bole »
Regular customer:
Hey Jim, could you make me a heart shaped frame?
Me:
(Should have been NO!)
What size?
Customer:
550x405
Me:
That would be doable but expensive
Customer:
Oh and it needs to have 50mm depth
Me:
When do you need it?
Well it is now done, and even though it was expensive it still wasn’t enough to justify the time. However, now that I have worked out the best way to do it, I have agreed to do do more of these.
Re: Probably should have said a big fat NO
Post by vintage frames »
Fantastic work.
'Frame of the Month'
Now you have to tell us how you did it.
Gesso&Bole
I started with 2 sheets of 3mm MDF, and used my laser cutter to cut out the heart shape cut into sections (the laser cutter is only 600x300). 2 wider layers for the front section and 22 layers that were thinner in 2 different cut patterns so the joins were overlapped on alternate layers.
I then glued it all together, sanded and painted.
Ingenious.
Tudor Rose
Organisation: The Framing Lot
Post by Tudor Rose »
:D Superb
Gesso&Bole
And here’s the artist holding the finished piece . . . Made from real tarantulas!
Apparently this one is destined for the RA later this year.
I’ve had orders for several more frames already, so I might have unwittingly found myself a niche!
GeoSpectrum
Post by GeoSpectrum »
You need a CNC Router now Jim.
That's awesome Jim! And such a relief to know where we can all come for a heart shaped frame now :lol:
Framer Dave
Post by Framer Dave »
Impressive! But what about the glazing? How was that cut?
Gesso&Bole
I have made quite a few of these now, and mostly I have used Acryguard acrylic from Centrado that I can cut on the laser cutter, but can also be scored and snapped by hand.
I have also done some with glass. I did this by softening the V at the top of the heart into a curve, and then by cutting it in three cuts, the first being the inverted 3 shape with the pointed V softened, and the other two cuts being the curved sides. I drew the shape on the glass with a sharpie, and did a trial run with float glass before doing it with AR glass.
Gesso&Bole
The most difficult part was actually creating the 50mm foam core spacers. I had to score the back of the spacer hundreds of times, so that I could bend to the shape without creasing on the front
toothy
Organisation: Framing
Interests: Piano, music, electronics, framing
Post by toothy »
This is phenomenal! What a great result. Totally worth the pain I reckon!
